Adjustable hydraulic valvetrane #1098301
10/20/11 09:05 PM
10/20/11 09:05 PM
templeton,ma
coro500net Offline OP
templeton,ma
I know this has been asked before but cannot find in search.
I have a 470 (400) with a Lunati 512 lift hydraulic cam and a set of Source heads and was wondering if there is any benefit of running adjustable rockers for a mostly street driven car? I have a well used set of factory hydraulic rockers in it now.If adjustable are the way to go, any recomendations and how to measure for pushrods? If factory setup is the way to go where can I find new rockers (seems everybody is out of them).
Re: Adjustable hydraulic valvetrane [Re: coro500net] #1098302
10/20/11 09:50 PM
10/20/11 09:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Measure the length to the rocker from the base circle
then add .020 to that length that will be the push
rod length.... as for the rockers you could use the
stock stuff... cant help you as to where to get them
Re: Adjustable hydraulic valvetrane [Re: MR_P_BODY] #1098303
10/21/11 02:06 AM
10/21/11 02:06 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I don't know big blocks much , but my small block with a mild hydraulic ( .480 lift and 238 @ .050 ) and decent springs punched a push rod through the rocker.
You don't need adjustability , but durability could be an issue.
There are H.D. stamped rockers out there , and this might be a nice choice for you.
I couldn't see forking out for T&D's , but an upgrade would not be a bad idea.
Re: Adjustable hydraulic valvetrane [Re: tubtar] #1098304
10/21/11 02:21 AM
10/21/11 02:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah I've seen stock rockers punched through... and yes
I was more referring to the HD stock stuff... which
I believe MP sold(dont know of other places)
Re: Adjustable hydraulic valvetrane [Re: coro500net] #1098305
10/21/11 01:25 PM
10/21/11 01:25 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I used the mopar adjustable pushrods way back on an xe284. They've worked well every since. I believe they are still available (search).
Re: Adjustable hydraulic valvetrane [Re: RemCharger] #1098306
10/21/11 07:48 PM
10/21/11 07:48 PM
dogdays Offline
dogdays  Offline
FWIW, stock and HD Mopar rockers are the same thickness.
R.
Re: Adjustable hydraulic valvetrane [Re: dogdays] #1098307
10/22/11 08:25 AM
10/22/11 08:25 AM
Ohio
Todd Offline
Todd  Offline
Ohio
I was at summit racing last week end and looking though the scratch/dent and discounted isle and saw a bag full of big block mp rockers. Don't recall the price but are usually less that retail. I know this doesn't help you it was at the store in akron. You could call them and ask it they still have them.
