dakota procharger 360 Cam? #1094838
10/15/11 04:56 AM
10/15/11 04:56 AM
Sweden
Tobbe Offline OP
Tobbe  Offline OP
Sweden
hi have a dakota whit a procharger ,street and strip still need to pass emissions looking for a cam that wake up the engine and dont is to bad at idle to set up the emmissions (HC)
still need something thats work whit future modīs like ,intake ,headers ,bigger throttle body ,etc
the only mod now is a ported stock kegger and ported rhs heads
a will make a better ex this winter whit the camchange
got as few recomendations ,dont mind a costomgrind
best so far is 8.68 1/8
a lot of tech only pick something direct from the catalog
here is a few cams
Comp Cams recommends staying at a 114 lsa.
The smallest cam for a 360 that would be better than stock would be a 200/206 .504/.512 114 lsa. It would be a super strong torque profile and is really a 318 torque cam. It would have 27-degrees of overlap. Overlap at .050 duration is: -25
A 206/212 .512/.512 114 lsa would still be a strong torque cam but is better suited for a 360. This cam will have 33-degree of overlap. Overlap at .050 duration is: -19
A great 360 boost cam with further modifications would be 218/224 or 224/230, but it is doubtful they would pass emissions with 45-degrees and 54-degrees of overlap Overlap at .050 duration is: -7 and -1
In addition,
A 212/218 .512/.512 114 Overlap at .050 duration is: -13
216/224 .506/.506 114 Overlap at .050 duration is: -8
Re: dakota procharger 360 Cam? [Re: Tobbe] #1094839
10/15/11 11:25 AM
10/15/11 11:25 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
You need to call Bullet Cams.
The comp cams recommendations won't take advantage of your ported rhs heads in my opinion.
Most of them will be very slow without a better torque converter.
A 210/220 @ .050 will be slow out of the hole without some more stall speed.
Precision Industries makes lockup converters that are great for your application and will help you get the most out of your combo by allowing you to use more cam...for the street too.
I would think you would want some more lift, while still keeping less overlap. More Duration will make more power with that supercharger.
Emissions...I really cant provide any guidance there. It's safe to assume anything more than the stock cam is likely to cause emissions issues....but leave that to the cam experts.
I would call a GOOD cam grinder and see what they have to say.
And if you decide you need more converter, call Precision Industries.
If you didnt want to change anything other than the cam, go with the [Email]206@.050.[/Email]
Re: dakota procharger 360 Cam? [Re: Tobbe] #1094840
10/15/11 11:47 AM
10/15/11 11:47 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I'd spend the money on the other mods you want first...Then the cam.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: dakota procharger 360 Cam? [Re: Adobedude] #1094841
10/15/11 04:11 PM
10/15/11 04:11 PM
Sweden
Tobbe Offline OP
Tobbe  Offline OP
Sweden
i have a build converter but still the stock "shell" the builder made max what he could do whit the stock core
Re: dakota procharger 360 Cam? [Re: Tobbe] #1094842
10/15/11 04:39 PM
10/15/11 04:39 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
The kegger intake is really holding you back, ported or not. I ran a stock one, ported one and went to a M1 and it was a huge difference. IMO, that is the first thing I would change.
Re: dakota procharger 360 Cam? [Re: TheOtherDodge] #1094843
10/15/11 06:36 PM
10/15/11 06:36 PM
Sweden
Tobbe Offline OP
Tobbe  Offline OP
Sweden
yes i now ,still more easy to change later on ...
anyone have a clue about cams
Re: dakota procharger 360 Cam? [Re: Tobbe] #1094844
10/16/11 12:16 AM
10/16/11 12:16 AM
Houston, Texas
Houston, Texas
Ok, change the cam and still have the restriction of the intake limiting your rpms.
Re: dakota procharger 360 Cam? [Re: TheOtherDodge] #1094845
10/16/11 03:08 AM
10/16/11 03:08 AM
Sweden
Tobbe Offline OP
Tobbe  Offline OP
Sweden
yes i now the kegger limit my rpm/hp
but the intake is 1.5 hour of work to change ,cam,springs etc are not
Re: dakota procharger 360 Cam? [Re: Tobbe] #1094846
10/16/11 03:55 AM
10/16/11 03:55 AM
Texas Afghanistan Iraq etc.
DakFink Offline
DakFink  Offline
When is the last time you changed a Cam???
With that comment not too recently. Intake has to come off to change the cam. And the Springs are about 1.5hrs per head.
and to answer your question
1-800-BulletCams or 1-800-LSMengineering!!!
Either company can get you what you need.
Re: dakota procharger 360 Cam? [Re: DakFink] #1094847
10/16/11 02:49 PM
10/16/11 02:49 PM
Sweden
Tobbe Offline OP
Tobbe  Offline OP
Sweden
sorry if you got me wrong iīm not write on my first language....change intakes is aprox 1.5hour .....cam spring etc are NOT
is there anyone who has experience about a similar build
Re: dakota procharger 360 Cam? [Re: Tobbe] #1094848
10/16/11 03:33 PM
10/16/11 03:33 PM
Houston, Texas
Houston, Texas
"is there anyone who has experience about a similar build"
Yup, I have both turbo and supercharged trucks and gave my advice.
Re: dakota procharger 360 Cam? [Re: TheOtherDodge] #1094849
10/16/11 03:59 PM
10/16/11 03:59 PM
Sweden
Tobbe Offline OP
Tobbe  Offline OP
Sweden
ok thanks ,what cams do you run? intakes ets ,rpms
Re: dakota procharger 360 Cam? [Re: Tobbe] #1094850
10/16/11 10:29 PM
10/16/11 10:29 PM
Antioch, CA
lucky13 Offline
lucky13  Offline
Antioch, CA
custom bullet cam with the springs they advise, along with an m1 4bbl and a bigger TB. Install them all at the same time. Why waste the energy/time of bolting a ported kegger back on?
Re: dakota procharger 360 Cam? [Re: lucky13] #1094851
10/17/11 03:22 AM
10/17/11 03:22 AM
Sweden
Tobbe Offline OP
Tobbe  Offline OP
Sweden
one thing that you U.S. residents do not have to think about is freight customs tax etc.
an intake of $ 600 + shipping aprox $ 100 + 35% customs + tax total
$ 945 when I have it at home at the door
Therefore, I have think most hp for money and what you can do and grow later
a intake or a throttle body i could prob get used somwhere
