Re: How much power can a 8.75 rearend handle?
[Re: robnbird]
#1094462
10/23/11 10:33 AM
10/23/11 10:33 AM
Challenger 1
Cincinnati, Ohio
If I have to ask about a 8 3/4 Im not going to be very confident. better off with a 60 or a 9" ford in my oppenion.
OMG you said 9" ford on a Mopar site!!
[Re: Super Scamp]
#1094463
10/23/11 11:32 AM
10/23/11 11:32 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Going on 8+ years all in the 10`s at 3200lbs. and I run the 742 case w/Richmond 4.11 gears, Dutchman 30 spline axles, stock caps and a backbrace.
LUCKY...Is correct word in this post.
The time is going to come when all of you 10 second cars hook up 1 good time and the weak link is going to cause you to spend lots of to fix you Trans/rear/and maybe the motor.
You all need one of these...
I've been in the 8s with my 8 3/4... like I've said a thousand times "I think its a weight issue"... JMO
[Re: Thumperdart]
#1094466
10/23/11 12:59 PM
10/23/11 12:59 PM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
I ran a string of 10.70's on my 8 3/4 this year. Stock axles, stock caps stock gears and a stock cone sure grip. The car is 3400 race weight with exhaust on. HOWEVER I have a big squishy converter, and I think the 3.23 gears are saving the axles. Best 60' was a 1.55 buy most were 1.59-1.61. I plan on changing to a Dana 60 this winter. Here is a video of a 1.61 leave. It doesn't look like this set up will break anytime soon, but it's a boring launch. http://www.youtube.com/watch?v=8-PO1bCE3E0&feature=youtube_gdata_player-Kenny
[Re: Challenger 1]
#1094468
10/23/11 06:52 PM
10/23/11 06:52 PM
Posts: 16,477 Canada
CrAzYMoPaRGuY
Canada
Binder Dundat.
Pooched 6 different pumpkins with different brands of brand new gears, spool, 31 spline 4 spider posis, WAR cases, nodular cases, you name it. Jamie Roth, Ian Wood, the crazy AMC guy in Mission, everybody tried to build me a third member, none lasted!
No more 9" rears for THIS guy!!!!
CrAzYMoPaRGuY
[Re: FastmOp]
#1094471
10/24/11 12:56 PM
10/24/11 12:56 PM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
In may I was down to eight cars and the chick I was racing went red. I had a 5.99 dial in on it when the 8&3/4 let go. It broke the trans too. So I stuck a Dana in it, now I can tranzbreaking it every pass and not worry
The last street gear I had broke the teeth on the ring gear on the final points night with 4 rounds to go. I needed one more round to win the track championship. That thing made it through 4 more passes and not only did I win the championship but I won the race too. When I pulled it apart the next day I was amazed it lasted the rest of the night. It looked like it shouldn't have made it onto the trailer.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Dap]
#1094475
10/25/11 11:07 AM
10/25/11 11:07 AM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
I think if you sit down with a piece of paper and cost out making the 8 3/4 stronger vs installing a Dana, you will have your answer. Either way get some good axles in that thing. BTW congrats on your promotion!
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
