64 pushbutton trans need help!
#1094072
10/14/11 07:11 AM
10/14/11 07:11 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
i have a 64 belvedere 440 w/pushbutton trans. Can this be switched to a racing shifter on floor? without changing trans. was told no, looking for confirmation thanks
Hell Hath No Fury Like Mine
Re: 64 pushbutton trans need help!
[Re: sixpacksteve]
#1094073
10/14/11 09:09 AM
10/14/11 09:09 AM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
I was told that there was a floor shifter for racing at one time but it would be almost impossible to find. I still use the buttons on the dash and i go 9.67 and have no problems.
There is a company that has a floor shifter but it is not gated and i have seen the buttons moved to a platform on the drivers right to allow using the right hand to shift buttons.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: sixpacksteve]
#1094074
10/14/11 10:22 AM
10/14/11 10:22 AM
RapidRobert
There was a recent thread that might help you, a VB or possibly a rooster comb change may let you use a floor shifter. Google it
[Re: RapidRobert]
#1094075
10/14/11 10:30 AM
10/14/11 10:30 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I seriously doubt a valve body change would work, the old PB 727's had rear pumps the new ones don't. The problem is how it's shifted.
Best I can think of is using a floor shift from an early MoPar, such as my 65 Cuda, and modifying the action to be more race oriented.
[Re: Supercuda]
#1094076
10/14/11 11:13 AM
10/14/11 11:13 AM
RapidRobert
Google it & find that comprehensive thread, I think it can be done
[Re: RapidRobert]
#1094077
10/14/11 11:47 AM
10/14/11 11:47 AM
Savoy1964
Casco, MI
The 64 A-100's used a shifter mounted on dash but again its not gated so you could shift past where you intend and I am not sure if it has all the gear selection R N 3 2 1 that is needed park is separate.
[Re: dOc !]
#1094080
10/14/11 03:59 PM
10/14/11 03:59 PM
RapidRobert
Doc I remember that pic in a magazine from way back and the article made a reference something to the effect that they pirated it from a space ship/starship enterprise garage sale something or other. It always stuck in my head and I'd forgotten about until now. I'd like to make one (prob should get a PB tranny 1st)
[Re: sixpacksteve]
#1094081
10/14/11 05:34 PM
10/14/11 05:34 PM
Posts: 25,729 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you can find a '64-'65 console shifter it can be used with any '62-'65 trans if the corresponding console/column shift valve body is used.
[Re: RapidRobert]
#1094083
10/14/11 08:07 PM
10/14/11 08:07 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
i spoke with jerry stein he said same thing. find a 64-65- floor shifter or dash. but said to stick with the pushbutton setup!
[Re: sixpacksteve]
#1094084
10/15/11 05:43 PM
10/15/11 05:43 PM
John_Kunkel
Rio Linda, CA
The PB valve body doesn't have the extra notch for Park, if you hook a PB valve body to a console/column shifter the cable core will buckle and bend when the shifter is placed in Park....every shift after that will be off because of the bent cable core.
Also, the shift cable core retaining notch is different and a console/column cable won't properly shift a PB valve body.
[Re: dOc !]
#1094085
10/15/11 08:46 PM
10/15/11 08:46 PM
Posts: 2,431 USA
SSAAHemiFan
USA
There is a hemi- with a home-made floor shifter ....but HERE is one that was made back-in-the-day.....
I had one of those.. Art Carr "Nifty Shifter" -came with a B&M ball and trunion clutchflite I bought.. sold the shifter to a guy restoring a nostalgia gasser - Art told me he just used the pushbuttons out of a Dodge pickup.
[Re: bboogieart]
#1094090
10/17/11 08:13 PM
10/17/11 08:13 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
OK car has been sitting since 1983 w/trans in car i put a 440 in it. just got it running. seems it is stuck in gear. i can push all of the buttons and they seem to work but won't go into neutral or any other gear.any ideas what to do next without ripping it apart?
[Re: John_Kunkel]
#1094094
10/18/11 06:43 PM
10/18/11 06:43 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
ok, this morning, dropped pan readjusted the cable. put everything back together . hit all the gears,GREAT! then later tested it again NOTHING it won't go into gear, stuck in neutral. i guess back to the drawing board.
[Re: sixpacksteve]
#1094097
10/18/11 07:05 PM
10/18/11 07:05 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
when i push the buttons it seems to shift, just nothing happens doesn't go into gear.
[Re: dOc !]
#1094101
10/18/11 11:08 PM
10/18/11 11:08 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
yes,i had friend shift while i adjusted it. it was perfect. test drove it was fine.. then test drive again squat. i'm going to drop the pan again. something is not right with the cable. where would i get a new cable?
[Re: dOc !]
#1094103
10/19/11 12:18 PM
10/19/11 12:18 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
If you've already done so my apologies for doubling up on this, but did you change the filter? I've had these plug up after sitting a long time. I'm in the middle of the same thing with a Coronet that sat for a long time. Got it running, tranny worked for a few tries and then nothing. Filter was plugged.
Lead, follow or get the hell out of the way
[Re: peabodyracing]
#1094104
10/19/11 04:24 PM
10/19/11 04:24 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
no, i didn't try that. its raining but i'll change filter as i check cable position.
[Re: sixpacksteve]
#1094105
10/19/11 04:55 PM
10/19/11 04:55 PM
John_Kunkel
Rio Linda, CA
If in doubt about whether the cable is moving the roostercomb, just pull the NSS and you can observe the movement of the roostercomb.
[Re: John_Kunkel]
#1094106
10/19/11 06:05 PM
10/19/11 06:05 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
ok john, forgive me but whats roostercable, and nss? thanks
[Re: sixpacksteve]
#1094107
10/19/11 07:38 PM
10/19/11 07:38 PM
John_Kunkel
Rio Linda, CA
The roostercomb is the internal shift lever that the spring-loaded ball sits in to make shift detents, NSS is Neutral Safety Switch.
[Re: sixpacksteve]
#1094109
10/20/11 10:47 AM
10/20/11 10:47 AM
Posts: 404 Central New York
bfury
Central New York
I also had the same problem with the filter, you can cut the second hole in the filter and it will work. As far as the shift cable adjustment, I pushed the neutral pb in and then adjusted the cable so that the neutral safety switch was depressed and all worked fine.
Now where do you buy that tee shirt?
No Stock
[Re: bfury]
#1094110
10/22/11 12:54 PM
10/22/11 12:54 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
Ok update! dropped pan,changed filter, watched as cable was shifted everything moved fine,worked fine etc.. put everything back together and nothing! buttons push in,they stay in,they change nice when you switch gears. zero zip! WHAT gives? How does it go from working one minute then nothing?
[Re: dOc !]
#1094112
10/22/11 03:41 PM
10/22/11 03:41 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
my buddy just called he said check line pressure too! ZERO, says i have wrong convertor and killed the pump and probably the convertor too!
[Re: John_Kunkel]
#1094114
10/23/11 08:04 PM
10/23/11 08:04 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
just picked up a later 727, hopefully this will work.
[Re: dOc !]
#1094116
10/26/11 08:42 PM
10/26/11 08:42 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
its a 74 going with a full rebuild and a rev man valve body , b&m shifter, this should work!
