Page 3 of 3 1 2 3
Re: T-56 or a 5 speed? [Re: finadk] #1092507
11/04/11 03:47 AM
11/04/11 03:47 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
YOu need to figure out what is the lowest RPM your car can pull, and keep in ming that if the engine is lugging you may get worse fuel mileage than spinning it at higher RPM.
Yup, and I hope anyone smart enough to do their own 6-sp install would have the foresight to take into consideration how low of a rpm you can really run your engine before you start dropping below your efficiency zone. Camshaft and carb type or efi will make the difference in this case. I think you would need a 4.10 or numerically higher gear with a .5x 6th gear.
Also, I believe the OEM T-56's in the gto, cadiallac cts-v and the camarobirds had a .57 6th gear ratio.
Re: T-56 or a 5 speed? [Re: 268RTs4ME] #1092508
11/04/11 01:51 PM
11/04/11 01:51 PM
New York
Fuller Offline OP
Fuller  Offline OP
New York
Yeah. I will have it mated up to dana 60 with a 4.10 rear end. I am looking for a decent highway cruise to go alone with that rear end.
I was just wondering if anyone has dimensions for a crossmember that someone has used.
Re: T-56 or a 5 speed? [Re: 268RTs4ME] #1092509
11/05/11 08:58 AM
11/05/11 08:58 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
TKO. Keisler 5 Speed. 2150 (APPROX) @ 70 MPH. 354 Dana. Just right. 69 Coronet R/T. Like having the A833 with a taller bonus gear.
Re: T-56 or a 5 speed? [Re: DennisH ] #1092510
11/05/11 10:00 AM
11/05/11 10:00 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
the TKO I had with the .64OD was too much for me with 3.21 gears, and was just right with 4.56s. with a 6th gear OD in the .5x range I'd have to have run 4.88s!!
3.21s my 5th gear was lugging at 1800 rpm at 60mph and I had to get up to about 75mph to get the engine to smooth out.
4.56s was a smooth 2400 rpm at 75 mph. perfect!
that was with a 28" tire too, so a shorter tire will help out.
**Photobucket sucks**
Page 3 of 3 1 2 3
