any picts of door post catch repair. #1092428
10/11/11 12:18 AM
10/11/11 12:18 AM
glendora, ca.
Deepockets Offline OP
glendora, ca.
i've noticed on the driver side post that it's cracking around the washer that goes under the screew in catch for the door. the car is very nicely painted and would like to see some ideas that you've done to that area with out having to weld and repaint.
Re: any picts of door post catch repair. [Re: Deepockets] #1092429
10/11/11 12:25 AM
10/11/11 12:25 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Well, it holds the door closed. Weld and repaint is the only procedure I would do. Spotting in that little bit of paint shouldn't be a problem. Man, I can remember selling my 69 340-S aropund 1980 because that little problem scared me off the body. I wouldn't make that mistake today, pretty easy fix to do it right.
Sheldon
Re: any picts of door post catch repair. [Re: RUNCHARGER] #1092430
10/12/11 03:53 AM
10/12/11 03:53 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
