Re: VACUUM AT IDLE
[Re: Moparnut426]
#1092152
10/10/11 03:45 PM
10/10/11 03:45 PM
Posts: 5,080 organ
maximum entropy
organ
i have less than 3" @ idle. power valve selection isn't nearly as critical as some would lead you to believe. it doesn't affect idle mixture at all, only the main circuit. i still run a 65 pv with no problem. more important would be your cruise vacuum. mine is ~15", meaning the power valve is closed (as it should be) at cruise.
Re: VACUUM AT IDLE
[Re: bigsbigelow]
#1092155
10/10/11 04:27 PM
10/10/11 04:27 PM
Posts: 5,080 organ
maximum entropy
organ
If you want better cruising mileage you need a power valve.
correct. get a power valve in that thing! oh, and don't forget to jet down on the primary side (assuming you'll have a power valve on primary only). 8 numbers down should do it.
Re: VACUUM AT IDLE
[Re: Moparnut426]
#1092157
10/11/11 11:10 AM
10/11/11 11:10 AM
Posts: 12,379 Taxes & Virus's R-US, NY
Dragula
Wha spread does a guy usually run as for jets, Like 80 rear, 70 fronts?
os it 10, 8, 6?
Just curious.
Spread them to start off with at 8...It may go as high as 10 on the spread, but usually 8-9 jets between them.
