Re: Edelbrock rpm head questions.....................
[Re: BradH]
#1092041
10/10/11 01:04 PM
10/10/11 01:04 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Dom, I agree with Brad. If you dont have a flow bench, and know HOW to interpret the numbers, you could be doing more damage than good. Ebrocks have a pretty good port and chamber as is, BUT, they do respond totally different, or let me put it this way, they have TOTALLY different needs from the intake ports to the exhaust ports. There are several things that they really respond well to, and other modifications that you will just go backwards or at least simply waste your time. What I am saying is they have spoecific areas where porting and valve jobs do a great deal, as well as some other changes. If you dont know where to look for that, then I'd say stay away from them, or have an experienced porter ( somoen who knows Ebrocks) mess with them. ( not even consdiering the camshaft likes and dislikes) .\ This is exactly while you'll see some real turd Ebrock combos, and some exceptional ones, that overachieve. It comes down to the porters knowledge, and the cam combo. I have quite a few Ebrock combos out there and have found this to be true. My experience and
RIP Monte Smith
[Re: moparniac]
#1092043
10/10/11 01:14 PM
10/10/11 01:14 PM
CompWedgeEngines
Syracuse,NY
Maybe you can let him borrow your 3/4 race cam and that extra set of pop ups ?...and throw some " fifties" on the back end with some Purple Hornies?...
RIP Monte Smith
[Re: Thumperdart]
#1092051
10/10/11 08:17 PM
10/10/11 08:17 PM
Posts: 2,177 ill
dennismopar73
ill
thumper ,, a close friend had stock eddies rpm, 452, mp intake, 13-1 comp, 8" t/a 5000 stall , dana 430 geared,31 tall tire, dominator ,on alcohol,3250 # 73 duster, all steel car! racer brown stx 21 car ran high 9.70 low 9.80 on the back bumper! so it can be done without going to big heads and roller stuff and spend alot less money
[Re: Thumperdart]
#1092055
10/11/11 11:08 AM
10/11/11 11:08 AM
Posts: 3,210 robin hood country
deaks
robin hood country
About 40 hp needed, more comp would help that cam, lose some weight. I think you're car runs well, i would like to be where you are. Prosports car was max wedge port, tunnel ram and a bit lighter than yours and his has gone 9.77. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
