What cam is this? #1088619
10/05/11 01:03 AM
10/05/11 01:03 AM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
I finally got the cam out of the engine I bought. The engine is a rebuilt 1974 440 with steel crank. One cylinder had water in it but it looks to be a low mileage rebuild, albeit it came out of a mud bog truck that broke and rolled. The end of the cam has alphabet soup stamped into it. No brand names.
272 P
64-1
1424
8A5H
I googled the crap out of it. The only cam I could find was a CamCraft.com. You can see the specs on the cam under letter "C". It's labelled 21-1424
I plan to put a call in to them unless one of you motorheads can ID this baby.
So if these are the true numbers, how aggressive is this cam? Is it like the old 282 MP purple Hyd cam? Lift, duration, lobe separation, it's stuff I have heard for years but it's still greek to me.
Lindy
I’m listening.
Re: What cam is this? [Re: Big Bad Bee] #1088620
10/05/11 12:40 PM
10/05/11 12:40 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
check the front of the cam
Re: What cam is this? [Re: emarine01] #1088621
10/05/11 01:26 PM
10/05/11 01:26 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Looks like stock cam markings to me, or maybe a MP grind also. They really dont have any kind of ID with numbers... They have stamps and marks, but I havent ever figured out what they mean.
Take some calipers and measure lobe lift... Pretty simple, and you will get a idea of what it is.
Re: What cam is this? [Re: emarine01] #1088622
10/05/11 01:30 PM
10/05/11 01:30 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I think your right.
You can setup some v blocks, like a cyl head, on the rocker pedastals, and turn it with a dial indicator , and get the actual lobe lift #s. then X that by 1.5.
Make sure you check an int. and an exh lobe.
Re: What cam is this? [Re: RemCharger] #1088623
10/05/11 01:44 PM
10/05/11 01:44 PM
Spokane Valley, WA
Spokane Valley, WA
Called CamCraft. Nope. They don't claim it. They usually don't mark their cams. The owner said that it's likely a custom grind/regrind and said that I need to look at the casting for marks but even that won't likely tell the story. Might be an older Crane Cam number set, referring to the 1424. Suggested I go to someone with a "Cam Doctor" to have it measured.
I'm going to call my engine guy and see what he's got. Maybe do the calipers and dial indicator for fun.
Thanks for the suggestions, guys.
Lindy
I’m listening.
Re: What cam is this? [Re: Big Bad Bee] #1088624
10/05/11 02:02 PM
10/05/11 02:02 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Lindy
In all honesty though do you really plan on re using it? If its a solid flat tappet, or hydraulic cam is it worth saving especially if you dont know what specs is ground on. I guess for what Comp will sell you a nice cam and lifter set for I would just buy a new one, but if your on a tight budget I understand that also.
kasey
Re: What cam is this? [Re: Big Bad Bee] #1088625
10/05/11 02:19 PM
10/05/11 02:19 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
272 P
64-1
1424
8A5H
Lindy
Its odd they don't claim that cam, The 272 is the Adv. Dur., The 1424 is the core #, Its ironic that on there cam chart it shows the 1424 as a .272, i'd measure the lobes.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: What cam is this? [Re: joedust451] #1088626
10/05/11 03:53 PM
10/05/11 03:53 PM
Daytona Beach, FL
cknight Offline
cknight  Offline
Daytona Beach, FL
If it's a single bolt camshaft, it could be one of the old Crane private label hydraulic lifter grinds. Duration at .050" would be 214 intake, 224 exhaust. Timing at .050" is: Intake opens 0 BTDC, intake closes 34 ABDC, exhaust opens 49 BBDC, exhaust closes 5 BTDC. Advertised duration is 272 intake, 282 exhaust, at .004" lobe lift. Lobe separation is 112 degrees. Lobe lift is .2947" intake, .310" exhaust, providing a gross valve lift with 1.5:1 rockers of .442" intake, and .465" exhaust. Regards, Chase
Re: What cam is this? [Re: cknight] #1088627
10/05/11 04:04 PM
10/05/11 04:04 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Cam Dynamics, or Blue Racer, was popular, and look similar IIRC
Re: What cam is this? [Re: Bob_Coomer] #1088628
10/05/11 04:24 PM
10/05/11 04:24 PM
Daytona Beach, FL
cknight Offline
cknight  Offline
Daytona Beach, FL
The Cam Dynamics part number 15215 is this same grind, but the camshaft would have been stamped CD 290 H12. Wolverine/Blue Racer did have a lower lift grind, again 214 and 224 at .050", and would have been stamped 1162. Regards, Chase
Re: What cam is this? [Re: cknight] #1088629
10/05/11 11:20 PM
10/05/11 11:20 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
With those lift and duration specs...I'd use it for a tow vehicle. I'm sure it would make plenty of low end torque.
Re: What cam is this? [Re: Labratt] #1088630
10/08/11 07:05 AM
10/08/11 07:05 AM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
I believe its a General Kinetics "P" series cam. The circle arrow is a GK logo if i recall. But the specs re the same that Chase quoted . I think I still have one on a shelve somewhere. I'll see if it matches your picture.
Re: What cam is this? [Re: 6PACMAC] #1088631
10/08/11 06:50 PM
10/08/11 06:50 PM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
Yeah, you have a General Kinetics cam there. The stamped logo is the same as the logo on a sb General Kinetics cam I have. Can't find my bb cam like yours. Maybe sold it? It also has the same specs as the "small" Summit cam.
Re: What cam is this? [Re: 6PACMAC] #1088632
10/11/11 01:55 AM
10/11/11 01:55 AM
Spokane Valley, WA
Spokane Valley, WA
Thanks! I hadn't checked back to this post for a couple days. I am always astounded by the wealth of knowledge here. I am ditching the cam for something more aggressive. The block goes to the engine builder this week to see if the bore can be fixed. With me luck.
Lindy
I’m listening.
