Re: 440 question
[Re: MoparJunkie]
#108841
08/22/08 10:40 AM
08/22/08 10:40 AM
RapidRobert
915 heads with KB pistons(in the CR you want) & .035"-.040" quench(piston to head).
Re: 440 question
[Re: Mr.Yuck]
#108843
08/22/08 12:25 PM
08/22/08 12:25 PM
Posts: 1,129 Home of the Bluegrass
MoparJunkie
Gonna go with 4 speed and 3.91 gear.....
"It takes a Mopar to catch a Mopar” 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: 440 question
[Re: MoparJunkie]
#108846
08/22/08 01:53 PM
08/22/08 01:53 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
If you do not have a rotating assembly I would recommend a stroker kit. Your choice on how much you want to spend, but they do not have to cost that much.
No replacement for displacement!
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
Re: 440 question
[Re: DaytonaTurbo]
#108848
08/22/08 05:22 PM
08/22/08 05:22 PM
MoparJunkie
I want to get 500 hp.... but look as stock as possible? ie...sleeper. As much as a sleeper as a six pack can be...lol Would like to keep cast heads? If possible don't want to stroke either. Can I get that with bigger flat top pistons and good sized cam with ported and polished heads????? Like I said just don't want to get too radical!
Re: 440 question
[Re: MoparJunkie]
#108849
08/22/08 07:23 PM
08/22/08 07:23 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
In all honesty, a rebuild with KB flat tops set to 0 deck, anda medium sized hydraulic cam (230ish duration at .050) will make 500hp or very close if it's done by a performance shop. It's not magic, nor expensive. No exotic heads, just a good performance 3 angle valve job, adn excellent machining gets you there.
Re: 440 question
[Re: MoparJunkie]
#108850
08/22/08 08:22 PM
08/22/08 08:22 PM
Posts: 4,310 Prospect, PA
BSB67
Prospect, PA
Good for you. Your asking the right question at the right time. You'll get lots of good info, but some of it might sound conflicting at times. You'll need to sort through it and decide what is best for you, based on budget, performance goal, and streetability. You might identify your performance goal in terms of et and mph, and your idea of "streetability" as the responses you get will be even more on-point. A flat top piston with 915s and a tight quench distance will perform very vey well, however, I think that combo will push the CR up close to 11:1 and might be difficult to use pump gas. But if you want a big cam with lots of lope, you might be able to get away with it. Others have used the reverse dome KB piston, pump gas, iron head, small cam (224* 0.050") and flirted with 12s with BF Goodrichs and 3.23s. Having well prepared heads is key. Good Luck
Re: 440 question
[Re: BSB67]
#108851
08/22/08 08:28 PM
08/22/08 08:28 PM
MoparJunkie
Tight quench meaning deck the block mill the heads????
Re: 440 question
[Re: MoparJunkie]
#108852
08/22/08 09:31 PM
08/22/08 09:31 PM
Posts: 5,117 Haslett, MI
7DRRunner
Haslett, MI
sounds like a nice project
subscribed for more info
"Good luck on your project."
1970 Road Runner
"Accellertii Incredibus"
Re: 440 question
[Re: MoparJunkie]
#108854
08/22/08 10:19 PM
08/22/08 10:19 PM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
I'm a firm believer in Bob K's Mr. Sixpac cam... Idles like a stone stock engine, runs well into the 12's with gears on bias plies. Ask on the A-12 board I'm using one in a 383... putting a 6bbl set together for it (slowly) even with the 4bbl it does fine... needs more gear, your 3.91's are that's what I have to install soon. 10:1 915's good valve job! Shoot for squish! Bob K's cam Bobs Super Bee
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: 440 question
[Re: R70RUNNER]
#108856
08/22/08 10:49 PM
08/22/08 10:49 PM
MoparJunkie
Be more specific on squish.....decking the block? or milling heads?
Re: 440 question
[Re: HealthServices]
#108858
08/22/08 10:59 PM
08/22/08 10:59 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Weight your options on heads too. Check out how much to do all the work on a iron head before you shell out the money. Porting is not cheap. If it gets anywhere past $600 you may be better off getting a aluminum head like that from 440 source. You will also have less tendency to detonate with aluminum heads. Another plus if you have junk gas where you live.
But on another note if you have the alcohol blended fuel (higher octane) where you live you should take advantage of it and build a high compression motor.
Allen
Re: 440 question
#108860
08/22/08 11:02 PM
08/22/08 11:02 PM
MoparJunkie
I have access to av gas, but don't intend on solely useing that as the norm....
Re: 440 question
[Re: BSB67]
#108861
08/22/08 11:04 PM
08/22/08 11:04 PM
MoparJunkie
So if you deck to 0 then your quench will be the thickness of the head gasket???
Re: 440 question
[Re: MoparJunkie]
#108862
08/22/08 11:04 PM
08/22/08 11:04 PM
R70RUNNER
Riverside, Ca
Here is a pretty good read... http://www.moparts.org/Tech/Archive/motor/38.html
I prefer squish, quench is the same thing..
You will need to deck the block to zero deck, or .005 in the hole is common. The 915's are closed chambered heads, CCH, makes it easier to obtain squish. It can be done with open chambers but much harder to do, and pop up, or quench dome pistons are going to be a necessity
Have a read
Re: 440 question
#108863
08/22/08 11:08 PM
08/22/08 11:08 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Oh be careful with big cam high compression in order to run that on poop gas you have to do some serios research for the street. Not a lot of fun if you get the combo off by just a little. I had one like that.
The Stealth heads look stock when painted if you want the stock look and want a relativey inexpensive head.
Allen
Re: 440 question
#108864
08/22/08 11:18 PM
08/22/08 11:18 PM
DaytonaTurbo
Manitoba, Canada
Quench means the top of the piston comes within .035-.050 of the head at TDC, once you figure in head gasket thickness and how far down in the hole the piston sits. There's really two kinds of quench. If you run a closed chamber head like a rebuilt/ported 915 or an edelbrock RPM / 440source stealth head and a flat top piston with a compression height of at least 2.060(KB237 would be a perfect piston for your build and cheap if you don't plan to run nitrous). When the piston gets really close to the head you get what's called quench. Having quench doesn't do much for producing more power, but it does allow you to run a higher compression ratio at the same amount of octane. Also a quench setup requires less ignition timing to get the job done.
The other type of quench setup is to run an open chamber head like a 906, 452, 346, etc any of the 1968+ factory big block heads with what they call a quench dome piston. With this style, the piston usually has a shorter compression height like ~2.03 or so, but has a tall 'dome' they call it. It doesn't really look like a dome to me, but you'll see it's a smaller raised area of the piston. The dome has to be machined to match up to the inside of your open chambered head. The result is with the dome and good machining, when the piston is at TDC, you get a similar combustion chamber shape as a closed chamber head/flat top piston combo, because that huge dome is taking up half of the space in the chamber. Needless to say, that setup requires some additional time spent measuring the dome, piston depth and cylinder head chambers and machining than the closed chamber style. With the closed chamber style all you have to do is mill the block's deck until the piston sits flush with the top of the deck, ie 0 down in the hole, then run a head gasket of about a .040 or so thickness and you're golden.
You don't have to run a quench setup, but it is beneficial, especially on a pump gas motor.
For the $ it takes to have stock cast iron heads, rebuilt, ported and bigger valves installed, you can almost buy a set of stock looking 440source aluminum heads, or a set of eddy rpm heads if you don't mind the aftermarket look. They will be closed chamber and flow as well or better than your ported stockers, plus the aluminum allows for more compression on pump gas. A 10.5:1 pump gas aluminum headed quench built 440 that runs on pump gas is easy. A cast iron headed non-quench motor will need to probably be around 9.5:1 to be pump gas friendly with a mild cam.
Also don't forget the 50lb weight advantage of the alum heads versus the cast irons.
Re: 440 question
[Re: MoparJunkie]
#108867
08/23/08 09:38 AM
08/23/08 09:38 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Hewre's my friends build 67GTX 6 pack ran 11.80's all day driven to and from the track. .030 over 440 10:1 TRW flat tops...ported (very ported) 915's, 509 cam (see and people think I hate on them), Aluminum 6 pack intake, Super comp headers, Mopar ingnition, 727 w/ shift kit an 5.0 leaver, 8.75 w/ 4.10's. Car ran great. Nothing fancy about the build but he did have some money in the heads, but back then there wasn't E-heads or the like. I'd think you could do the same except run a better "street" cam and you'll be way in the 12's. Maybe the mopar solid 528.
Re: 440 question
[Re: Mr.Yuck]
#108868
08/23/08 10:42 AM
08/23/08 10:42 AM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
Sounds right, 11.8s is a good number with that combo.
I had 452 heads ported on a 440 with an Ultradyne .591-.613 cam. Demon 825 race and MSD. The 4000 lbs Sport Fury ran 11.16 If I only shot a little juice at it, bam, in the 10s. It was a daily driver, but the 4.88 gear was a B!TCH on the highway even with 32 inch tires.
I have 3.08s in the new ride with a 32 inch tire. It won't run 11s, but who cares, it will run over 80 mph at under 3000 rpm.
Snap your neck, mega G-force launch, is all I want!
Re: 440 question
[Re: Mr.Yuck]
#108870
08/23/08 03:16 PM
08/23/08 03:16 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Thats very close to my combo. But I use 906 heads and KB quench pad pistons to get quench in my 440. It also is 10.0 comp and I use the MP .557 cam with 4.30's and a 29" tire. I run the Holley SD intake with an 850 DP. 11.50's so far in my 63 Sport Fury and I drive it everywhere. Ron
