Re: Do all body fillers shrink?
[Re: Hooligan]
#1087880
10/04/11 07:44 AM
10/04/11 07:44 AM
Posts: 18,157 Mass
DAYCLONA
Mass
do yourself a favor and lead the joints,keep body filler to a minimum, Eastwood.com has plenty of suppliies to accomplish this,....as far as paint prep, you'll get 12 answers to that one question,...but I'll recommend what I prefer, strip the car to bare metal, etch-prime with Dupont VARI-PRIME, I would double coat it, do not sand, then coat with Dupont 2K ureahane primer, block sand, recoat, block until straight, paint......
[Re: gtx6970]
#1087882
10/04/11 10:53 AM
10/04/11 10:53 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Bill,....I've used them, If anyone haz had reactions later in their paint, I would think it was poor prep of the area, if you don't leach out the tinning butter (acid) it could come back to bite you later, esp if you open up the solder with a file/sandpaper, and leave the surface coarse, acetone/laquer thinner the lead joint,...even factory lead joints if they've been ground/sanded apon Mike
[Re: DAYCLONA]
#1087885
10/04/11 08:39 PM
10/04/11 08:39 PM
Posts: 84 Minnesota, USA
Sublime70
Minnesota, USA
I agree; lead does not shrink.
[Re: PAINT IT BLACK]
#1087887
10/05/11 12:38 PM
10/05/11 12:38 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
If things are still moving around cutting it flat & buffing it out is only temporary.... If your patient I prefer to cut it open & wait for solvents to gas out.... Plastic filler moves allot less than primer...
[Re: Hooligan]
#1087892
10/06/11 02:31 AM
10/06/11 02:31 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I can't answer the shrinking question other than mixed properly,right temp and not put on too thick, then you shouldn't have a problem. I used fiberglass anywhere I weld after grinding to fill in any holes, pores, etc... then grind it mostly back off before filler. I use epoxy or etch primer before I apply any fillers.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
#1087893
10/06/11 07:14 AM
10/06/11 07:14 AM
Posts: 18,157 Mass
DAYCLONA
Mass
What about a year and a half of sitting in a shop with varying degrees of 30F to 120F?
It wasn't cut while sitting there, but shouldn't that about do it for gassing out?
I have watched what was a perfect black paint job become not as perfect just sitting there. I'm almost done with reassembly, so I'm hoping I can go back and do spot buffing to get it perfect-ish again...
Fillers will continue to "move" for decades, it will be more pronounced on dark coloured cars, that's why I always stress complete replacement of a panel, or skilled METAL reworking of a panel with no fillers,....grafts/patch panels, and bondo carved cars will come back to bite you years later,...just a matter of time
[Re: gtx6970]
#1087895
10/08/11 03:12 AM
10/08/11 03:12 AM
Posts: 2,679 Maple Ridge, BC, Canada
Barnabas_Kriss
Mike, have you actually used any of the eastwoods body solder?
I've heard of horror stories with paint reactions to it recently.
I used their lead-tin based solder, no problems at all.
