Re: ENGINE COMPRESSION CHECK- COLD? [Re: topbrent] #1086532
10/03/11 12:46 AM
10/03/11 12:46 AM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Brent,do these seal as well as the Fel-Pro's? What manufacturer? Thanks!
Re: ENGINE COMPRESSION CHECK- COLD? [Re: Labratt] #1086533
10/03/11 02:54 AM
10/03/11 02:54 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Great seal and an easy compression bump without the milling your heads.
A light coat of wet silver spray paint or copper gasket spray and you are good.
Mopar Performance $21.95
http://www.summitracing.com/parts/DCC-4286754/
There are also more expense Cometic and MrGasket MLS gaskets available in the ~.027 range
