Re: race car wiring
[Re: coronetville]
#1083745
09/27/11 06:40 PM
09/27/11 06:40 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I used a Painless wiring kit.The one I used was for a roll bar mount,but I made brackets and mounted it to the trans tunnel.It was very easy to install and it works great.
Re: race car wiring
[Re: coronetville]
#1083747
09/27/11 07:29 PM
09/27/11 07:29 PM
Chris2581
Jacksonville, FL
Sure! I'll get one for you later tonight.
EDIT..camera batteries are dead!! I'll get it tomorrow for sure.
Re: race car wiring
[Re: Chris2581]
#1083748
09/27/11 08:01 PM
09/27/11 08:01 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I prefer ARC when it comes to a racer budget wiring panel and harness. I have noticed that Jegs has their own brand too. Just depends on what you need.
There is some stuff out there that is incredibly nice but it will cost ya.
Most of my customers are very happy with the ARC stuff I have installed.
Leon
Re: race car wiring
[Re: coronetville]
#1083753
09/28/11 12:21 AM
09/28/11 12:21 AM
Posts: 3,354 ohio
HEMIDARTS
ohio
I just rewired my whole car. I went with a K&R unit. I was very impressed!! It came with every single wire and they were all labled and color coded. It also came with a huge laminated diagram that was very easy to follow. It comes with a sweet switch pannel also. They also have great customer service. I found them at a MOPAR show. I went with the super duty. It is not the cheapest by any means, but in my opinion its the best! Here is a link to them. K&R
Re: race car wiring
[Re: coronetville]
#1083755
09/28/11 01:48 AM
09/28/11 01:48 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
I usually build my own to suit the customer needs. Heres a few pics from a 68 Dart I wired a couple years ago. This is the under dash board that has the MSD, coil, shift lite control box and RPM box, relays and self reset breakers. I buy most components from Waytek Wire or Del City.
Free advice and worth every penny... Factory trained Slinky rewinder.........
Re: race car wiring
[Re: Evil Spirit]
#1083756
09/28/11 01:56 AM
09/28/11 01:56 AM
Evil Spirit
Newport, Mi
Back of dash. Switches, gauges, ignition and brake switches, and connectors for turn signal and front/rear wiring harnesses.
Re: race car wiring
[Re: Evil Spirit]
#1083757
09/28/11 02:02 AM
09/28/11 02:02 AM
Evil Spirit
Newport, Mi
Trunk panel with main shut off, fuel/start relays, with start solenoid and main breaker on back.
Re: race car wiring
[Re: Evil Spirit]
#1083758
09/28/11 03:01 AM
09/28/11 03:01 AM
Evil Spirit
Newport, Mi
Dash switches. Switches scourced from Waytek and I labeled them.
Re: race car wiring
[Re: coronetville]
#1083761
09/28/11 09:09 AM
09/28/11 09:09 AM
Posts: 315 Russiaville, IN
mopar376d
Russiaville, IN
I have rewired several cars and I like the ARCtouch panel the best. Inexpensive and comes with a relay panel. My 2
Why does divorce cost so much?
Because it is worth it!!!!!
Re: race car wiring
[Re: mopar376d]
#1083762
09/28/11 09:42 AM
09/28/11 09:42 AM
Leon441
Lynchburg, VA
Evilspirit you have some nice stuff. And about the time I was gonna jump on my soap box I saw your relay panel in the trunk.
Here is my little ole opinion. Many of these kits and panels are extremely attractive and neat. The neat little relay panel everyone mounts in their particular chosen location. Makes for a really nice neat job. But, I am a practical guy. Been doing electrical and electronic work for 30 years.
I would like to show these guys were they mislead their customers. Here it goes follow along. Your battery is most likely in your trunk.(If not disregard everything I am going to tyep). You run a large 15ft cable up to a distribution or simply to your starter realy or starter solenoid. You then run a #10 to your relay panel that is probably fairly short. 15 ft of #14 from the controled side of the relay back to the fuel pump in the rear of the car. 10ft of #14 from the relay panel to your fans, water pump of whatever on the nose of the car. Your fuel pump is now 30ft of wire away from your battery. Your fan and water pump is 25 ft away from your battery. If you run an alternater you run your wire back to the battery so the shut off works unless you have it relay controlled most don't. Your 12 volt battery without an alternater has about 12.8 volts. Put a meter on your fuel pump wire with it unhooked from the pump, 12.8 volts. Hook the pump up and check it. The battery still has 12.5 volts with the 6 amp load on it but, at the pump you only have 11.5 volts. Unless you run #4 welding lead to everything you are gonna have a voltage drop with running 12 volts up 30 ft of wire on anything that requires any power. Evil spirit seems to share my idea you need a realy at the rear of the car so you can pickup power from the battery limiting your circuit to 5 ft instead of 30 ft.
I also run relays up front for the fans. What I currently have looks like crap from ARC their generec relay boards are not pretty but you can do anything with how you want the relay to work. These ultra neat relay centers placed next to your ignition or wherever you choose are extremely neat. On OEM cars they do this for service and assembly but, you have an alternater. Our Magnum has a rear mounted battery and also has a fuse are relay panel in the rear so OEM is catching on too.
I'm not saying to disregard using these nice wiring harnesses but remember where your loads are, like the fuel pump in the trunk. Put a relay back there where it can actually do some good.
Leon
Re: race car wiring
[Re: Leon441]
#1083763
09/28/11 12:49 PM
09/28/11 12:49 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
I agree...
The heavy hitters like fan and water pump relays are under the hood, fuel pump relay (and battery) are in the back...Everything else is mid point, in the cab.
I have 3 ground lugs, back-middle-front all grounded back to the battery.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
