1971 cuda 440 6-pack? 1970? #1083474
09/26/11 11:10 PM
09/26/11 11:10 PM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
What are the differences between the 1971 440 six pack carbs for an automatic transmission and those for a manual transmission?
Also, what's the difference between the 1970 and 1971 setups?
Re: 1971 cuda 440 6-pack? 1970? [Re: lahatte] #1083475
09/26/11 11:17 PM
09/26/11 11:17 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Jetting and idle feed restriction.
Re: 1971 cuda 440 6-pack? 1970? [Re: 62maxwgn] #1083476
09/27/11 04:49 PM
09/27/11 04:49 PM
California
1970mopar Offline
1970mopar  Offline
California
I believe also that 70' carbs w/out N95 had no provision for a bowl vent on the center carb.
70' N95 equiped cars had carb bowl vents and these were carried over to the 71' carbs.
Re: 1971 cuda 440 6-pack? 1970? [Re: 62maxwgn] #1083477
09/27/11 08:00 PM
09/27/11 08:00 PM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
In terms of performance, which set is generally preferred? Is the 1971 setup tuned for restricted emissions?
