Re: Vent Window Frame Rechroming
[Re: djenkins83]
#1082518
09/25/11 11:24 PM
09/25/11 11:24 PM
Posts: 1,653 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
If you have a hard top, there is the rubber gizmo at the top of the door window run channel with two screws hidden below.
[Re: kentj340]
#1082522
09/25/11 11:45 PM
09/25/11 11:45 PM
kentj340
Cut and Shoot, TX
There was some soft black caulk under the rubber part. The other thread is good and was posted after I started posting mine. I did not need to grind down my posts to remove the pot metal part - the material was soft enough to shave off small pieces around the edges with a sharp tool. As mentioned in the other thread, there's another set of unused posts.
[Re: HEMICUDA]
#1082524
09/26/11 07:14 AM
09/26/11 07:14 AM
Will be test fitting these this week.
[Re: ]
#1082525
09/26/11 11:58 AM
09/26/11 11:58 AM
Posts: 74,970 U.S.S.A.
JohnRR
U.S.S.A.
Mike , making A body also ??
