Shaker Hood Trim Ring Not Lining Up
#1082319
09/25/11 06:31 PM
09/25/11 06:31 PM
Posts: 450 OHIO
faud88
OHIO
I have a original shaker hood and trim ring (I think). Problem is the ring doesnt line up at all with the holes in the hood. I am not sure if the ring is from a Cuda or a Challenger. Did these things line up with the studs this bad from the factory or is something wrong here.....
Re: Shaker Hood Trim Ring Doesnt Line Up
[Re: faud88]
#1082322
09/25/11 06:50 PM
09/25/11 06:50 PM
Posts: 450 OHIO
faud88
OHIO
[Re: faud88]
#1082323
09/25/11 06:54 PM
09/25/11 06:54 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Those studs sure look long. Do they screw into or are they cast as part of the Shaker ring?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: faud88]
#1082324
09/25/11 06:56 PM
09/25/11 06:56 PM
Posts: 450 OHIO
faud88
OHIO
[Re: faud88]
#1082325
09/25/11 06:57 PM
09/25/11 06:57 PM
Posts: 18,157 Mass
DAYCLONA
Mass
That's a Challenger ring, and a Challenger hood, i can't see the posts too well, but if they are threaded rod cast into the ring, it's a repro ring, the threaded studs on some of the repro rings leave a lot to be desired, an original ring will have posts cast WITH the ring, meaning a 1 pc construction, not embedded, an original "stud" will be somewhat tapered in construction, and cut with a speed nut type fastner, not a machine thread nut
[Re: faud88]
#1082330
09/25/11 07:45 PM
09/25/11 07:45 PM
Posts: 450 OHIO
faud88
OHIO
[Re: faud88]
#1082331
09/25/11 07:46 PM
09/25/11 07:46 PM
Posts: 450 OHIO
faud88
OHIO
[Re: faud88]
#1082332
09/25/11 07:47 PM
09/25/11 07:47 PM
Posts: 450 OHIO
faud88
OHIO
[Re: ScottSmith_Harms]
#1082336
09/25/11 08:19 PM
09/25/11 08:19 PM
Posts: 450 OHIO
faud88
OHIO
*Did you find the cast in part# on the rear?
No, I have nothing like that stamped into the ring. I must have a very old aftermarket replacment. This ring has been around for a while.
[Re: faud88]
#1082338
09/25/11 08:56 PM
09/25/11 08:56 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
As I said before, there are NO reproductions out there as accurate as your original, that one is no exception. The one I used to sell wasn't bad, but it too fell short of an original, however the stud placement was pretty close (best out there as AFAIK) and MIGHT fit an original hood, you can buy them here: www.restorick.com
[Re: faud88]
#1082339
09/26/11 12:55 AM
09/26/11 12:55 AM
Posts: 636 California
sixpaktoogo
California
I had an original Challenger Shaker hood and trim ring a few years ago. It did not have any part numbers or Pentastar on it. The ring was original without a doubt. My 70 Cuda's original trim ring does have the Pentastar and part numbers. I might be interested in your trim ring. If you want to sell it PM me.
