Re: Starter motor recommendations
[Re: 68LAR]
#1082006
09/25/11 11:00 AM
09/25/11 11:00 AM
Posts: 108 Wisconsin
MagnumExpress
Wisconsin
For the money, Go get a stock late 90's Truck starter, or buy one from Mopar Performance. The 2 are the same. I have used these on motors ranging from 350HP to 1000HP. Also up to 15:1 compression ratio. U will need to clearance starter a little to avoid contact with block, but I think they are a better unit than any aftermerket high dollar piece.
#9 in the world. 2006 IHRA Super Rod 2010 IHRA Div.5 Hot Rod Champion
[Re: MagnumExpress]
#1082007
09/25/11 11:48 AM
09/25/11 11:48 AM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
MOPAR MINI no shims,etc etc works awesome and cheap
[Re: 440Jim]
#1082010
09/25/11 12:50 PM
09/25/11 12:50 PM
Posts: 4,008 South Park, Pa.
68LAR
South Park, Pa.
The one that I use now is from a '90 Dakota. Maybe it's just plain worn out. It's a pain in the butt to change mine. I don't want to do all of that work for the same result. Quote:
Are your headers near starter? Your installation might be heat soaking your starter. A sheet metal heat shield might help your situation.
Yes they are. The one tube comes within a little less than a 1/4" of the starter. You may be on to something. I had thought that around 1/4" would be enough clearance.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
