Launch marks #1081560
09/24/11 04:39 PM
09/24/11 04:39 PM
NY,Poughkeepsie
87MO DAK Offline OP
87MO DAK  Offline OP
NY,Poughkeepsie
Well after today got rained out,I fooled around with the truck.
After a smokey..smoke show at the neighbors house ,I launched it in
my drive way ..The pic attached shows the marks.
They are M/T E/T streets 28x13.50s with 20 psi,
The truck runs 12-o.s and on good day's will run 11.80s..
My times are -60' low 1.70s to 1.80s
MPHs are from 112-116
with an ET of 12.0s to 11.80s
It's a 12" wide wheel ,with tube's,not screwed ,just high tack.
Any suggestion's on why it's only grabbing on the outer edges
of the tire? It dose the same thing on the track BTW, I have tried
lower and higher pressure's ,and it dose the same thing????
Re: Launch marks [Re: 87MO DAK] #1081561
09/24/11 04:40 PM
09/24/11 04:40 PM
NY,Poughkeepsie
87MO DAK Offline OP
87MO DAK  Offline OP
NY,Poughkeepsie
Re: Launch marks [Re: 87MO DAK] #1081562
09/24/11 05:40 PM
09/24/11 05:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats usually a sign of under pressure
Re: Launch marks [Re: 87MO DAK] #1081563
09/24/11 05:42 PM
09/24/11 05:42 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Tires old and dried out?
Re: Launch marks [Re: MR_P_BODY] #1081564
09/24/11 10:36 PM
09/24/11 10:36 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
x2
Re: Launch marks [Re: Jeepmon] #1081565
09/24/11 10:52 PM
09/24/11 10:52 PM
Mo.
racerx Offline
racerx  Offline
Mo.
x2
x3 cupling in the middle(low presure)
