GEN 3 hemi head ANOTHER QUESTION !!!!!!! #1081405
09/24/11 11:46 AM
09/24/11 11:46 AM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
5.7 head gaskets have a right and left side
6.1 head gaskets use the same gasket
now, put a 5.7 eagle head on a 6.1, what head gasket do you use?
Re: GEN 3 hemi head scratcher for the smart guys [Re: sixpackgut] #1081406
09/24/11 12:00 PM
09/24/11 12:00 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I'm thinking the 6.1 because of the bore but why does the 5.7 use a left and right?
Is it because the 6.1 doesn't use the EGR?
Re: GEN 3 hemi head scratcher for the smart guys [Re: MattW] #1081407
09/24/11 12:03 PM
09/24/11 12:03 PM
Charleston
Charleston
IDK! i have yet to figure out why they would make a right and left head
Re: GEN 3 hemi head scratcher for the smart guys [Re: sixpackgut] #1081408
09/24/11 01:52 PM
09/24/11 01:52 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Did some research and it looks like you use the gasket for the block or run into coolant leaks.
5.7 block = 5.7 head gasket
6.1 block= 6.1 gasket
Remenber I am no expert. LOL
Re: GEN 3 hemi head scratcher for the smart guys [Re: MattW] #1081409
09/24/11 01:59 PM
09/24/11 01:59 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
I think this has come up on here before. Zippy the smart guy said use the matching head gasket for the block you are using.
Re: GEN 3 hemi head scratcher for the smart guys [Re: 340RICK] #1081410
09/24/11 02:22 PM
09/24/11 02:22 PM
Charleston
Charleston
ok thanks guys.
Re: GEN 3 hemi head scratcher for the smart guys [Re: sixpackgut] #1081411
09/24/11 03:18 PM
09/24/11 03:18 PM
Charleston
Charleston
i just mocked my rockers up to check the cam in the engine and my pushrods are way short
does the eagle head take longer pushrods? or do the lifters collapse without oil in them? i'm thinking i need longer PRs
nevermind
i just checked mopar wholesale and pushrods are diffrent starting 09
Re: GEN 3 hemi head scratcher for the smart guys [Re: sixpackgut] #1081412
09/24/11 04:43 PM
09/24/11 04:43 PM
right between milan dragway & ...
Flite_727 Offline
Flite_727  Offline
the 5.7 has a right & left head because an egr passage runs thru the front of the head on the right side.
'06 Magnum R/T Daily driver, 5.7 N.A.- [email]12.63@109[/email]
Re: GEN 3 hemi head scratcher for the smart guys [Re: sixpackgut] #1081413
09/24/11 04:50 PM
09/24/11 04:50 PM
MN
hemidup Offline
hemidup  Offline
MN
nevermind
Ray, Are you using a factory 6.1 short block ie pistons, rods and crank?
Jerry Williams.
Re: GEN 3 hemi head scratcher for the smart guys [Re: hemidup] #1081414
09/24/11 05:07 PM
09/24/11 05:07 PM
Charleston
Charleston
nevermind
its a 426 small dish with valve reliefs JE piston. bought used
Re: GEN 3 hemi head scratcher for the smart guys [Re: Flite_727] #1081415
09/24/11 05:14 PM
09/24/11 05:14 PM
Charleston
Charleston
So? they couldnt just block it on one head? its stupid
Re: GEN 3 hemi head scratcher for the smart guys [Re: sixpackgut] #1081416
09/24/11 05:31 PM
09/24/11 05:31 PM
MN
hemidup Offline
hemidup  Offline
MN
nevermind
Gotcha, Zero deck? Reason I asked is with stock pistons, they're between .010" and .015" out of the hole. Most that I checked were .010". Using an Eagle head with a factory 6.1 short block might require a Cometic .051" head gasket.... I don't know the spec's for either of the VVT Hemi Gen 4 factory head gaskets. Hopefully Zippy will chime in.
Jerry Williams.
Re: GEN 3 hemi head scratcher for the smart guys [Re: hemidup] #1081417
09/24/11 06:18 PM
09/24/11 06:18 PM
Charleston
Charleston
nevermind
Zero deck. the head gasket that came off the engine is 040
Re: GEN 3 hemi head scratcher for the smart guys [Re: sixpackgut] #1081418
09/24/11 06:34 PM
09/24/11 06:34 PM
MN
hemidup Offline
hemidup  Offline
MN
nevermind
Sweet! You should be good to go then.
Jerry Williams.
Re: GEN 3 hemi head scratcher for the smart guys [Re: hemidup] #1081419
09/24/11 06:39 PM
09/24/11 06:39 PM
Charleston
Charleston
how much lift can the dog bone handle?
Re: GEN 3 hemi head scratcher for the smart guys [Re: sixpackgut] #1081420
09/24/11 07:54 PM
09/24/11 07:54 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
We need a sticky thread. I don't know if I should start a new post or try to keep everything together
I want to build a 450 to 500 5.7 to put in my daily driver. It has to run on the crapiest gas around. 5.7 with a 6.4 crank maybe a 6.1 cam or 6.4 I know the 6.4 cam wont fit aftermarket with the same lift and duration.
This is the question. What head to run I have new 5.7 eagle heads and apache heads the apache is out do to my opinion that it is to big for my application or am I wrong?
So 2003 to 2008 5.7 or eagle head which would be the best head for my combo Please factor in the cost of rebuilding the non eagle head.
Re: GEN 3 hemi head scratcher for the smart guys [Re: sixpackgut] #1081421
09/24/11 08:40 PM
09/24/11 08:40 PM
MN
hemidup Offline
hemidup  Offline
MN
With stock rockers... .600"
Jerry Williams.
Re: GEN 3 hemi head scratcher for the smart guys [Re: MattW] #1081422
09/24/11 08:51 PM
09/24/11 08:51 PM
MN
hemidup Offline
hemidup  Offline
MN
Matt, We made the most power from P&P 5.7 heads with lower flow #'s at .600" lift vs P&P 6.1 heads. Stock Eagle heads would be the next choice than the Apache's. Stock Eagles flow better under .400" than stock Apache's.
Here's a pic of an engine dyno sheet showing the ported 5.7 kicks the ported 6.1. BTW the ported 5.7 had 2.05" int/1.57" exh.
Jerry Williams.
Re: GEN 3 hemi head scratcher for the smart guys [Re: hemidup] #1081423
09/24/11 09:51 PM
09/24/11 09:51 PM
Charleston
Charleston
is that different engines or the same one and what size engine?
FWIW, stock windage tray doesnt fit a stroker. is there a windage tray part number for the 6.4 yet?
Re: GEN 3 hemi head scratcher for the smart guys [Re: sixpackgut] #1081424
09/24/11 11:03 PM
09/24/11 11:03 PM
MN
hemidup Offline
hemidup  Offline
MN
One engine a 418 and the other a 419. Same build, same cam spec's, except the 418 is on a 112 lsa and the 419 on a 114, same compression, same fuel and timing curve, same dyno.
We modify a stock windage tray to clearence the rod bolts on a stroker. May be able to use a 6.4 windage tray or buy an after market version.
Jerry Williams.
