B1 Original Vs B1 MC #1080724
09/23/11 03:10 AM
09/23/11 03:10 AM
Rock Springs
Bob_Coomer Offline OP
Rock Springs
How can you tell the diff between the two? What part number is P4349600? I see on the end of the head it says MC...
There is a casting on the end of the head also of B970..
Re: B1 Original Vs B1 MC [Re: Bob_Coomer] #1080725
09/23/11 03:11 AM
09/23/11 03:11 AM
Rock Springs
Rock Springs
Also is the pistons diff between the two?
Re: B1 Original Vs B1 MC [Re: Bob_Coomer] #1080726
09/23/11 10:46 AM
09/23/11 10:46 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Not sure on the part number thing. The difference is the intake valve is moved slighlty to allow for a bigger intake valve. In terms of flow from what I have seen there is about a 30cfm difference between the two heads.
Re: B1 Original Vs B1 MC [Re: Al_Alguire] #1080727
09/23/11 11:48 AM
09/23/11 11:48 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
No B1 expert here but I thought they were the same casting, they just machined the valve location in a different spot.
Re: B1 Original Vs B1 MC [Re: Bob_Coomer] #1080728
09/23/11 12:13 PM
09/23/11 12:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would believe that the valve pockets in the piston
is bigger for the 2.4" valve in the M/C head... normally
you run .1 bigger than the valve so the pocket would
be 2.4 for the B1 original and 2.5 for the M/C... same
castings with the M/C intake moved .050(I believe it is)
Re: B1 Original Vs B1 MC [Re: MR_P_BODY] #1080729
09/23/11 02:47 PM
09/23/11 02:47 PM
NEW JERSEY
BIGSPEED Offline
BIGSPEED  Offline
NEW JERSEY
The exhaust valve is moved .050 towards the wall to allow a .100 larger intake. Center punch the piston down the guide at 10 degrees before or after. Use a compass to sweep the reliefs you have to see where you are at. Set compass at half valve size. If you have B-1 pistons in it you may not have to do much to the reliefs if the piston manufacturer was a little generious with his cutter. Frank
Re: B1 Original Vs B1 MC [Re: BIGSPEED] #1080730
09/23/11 03:08 PM
09/23/11 03:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its the exhaust that moves... thanks for that info...
I thought it was the intake... I sold my B1M/C heads
so I dont have them anymore to look at
Re: B1 Original Vs B1 MC [Re: MR_P_BODY] #1080731
09/23/11 05:24 PM
09/23/11 05:24 PM
Rock Springs
Rock Springs
I was told By Scott Koffel to be able to reuse the MC rockers with Original heads, the exh rocker needs to be moved .040 towards the intake valve. So I assume the intake is moved away from the intake towards the wall? to allow the larger intake valve?
