long wheel studs #1080588
09/22/11 08:05 PM
09/22/11 08:05 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Why does the Nhra call for 3 inch long wheel studs in some classes?
Re: long wheel studs [Re: flatiron] #1080589
09/22/11 09:00 PM
09/22/11 09:00 PM
Guitar Jones Offline
I think what they require (I'll have to look again) is that the stud threads into the hex portion of the lug nut by at least the diameter of the stud. In other words a 1/2" diameter wheel stud would need to thread into the hex portion of the lug nut at least a 1/2".
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: long wheel studs [Re: Guitar Jones] #1080590
09/22/11 09:13 PM
09/22/11 09:13 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Exactly
The reason for needing a 3" stud is to accommodate the thickness of the aftermarket disc brakes and the thickness of the hubs of the wheels used. A 3" stud is the only way to get the stud through that thick of a wheel to get the proper engagement in the nut.
If you use a stock drum and steel wheel chances are pretty good you'll have the proper engagement with the factory studs.
Re: long wheel studs [Re: WILD BILL] #1080591
09/22/11 09:55 PM
09/22/11 09:55 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Thank you it was just a question of curosity. I had a guy try to tell me it was for strength and being a machinist for the last 25 years I knew that strength was only in the Dia. of the stud.
Re: long wheel studs [Re: flatiron] #1080592
09/23/11 11:05 PM
09/23/11 11:05 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Asking "why"
Be nice if reasons were sometimes given, but then you would have ammo to ask questions, and that likely is frowned on.
My guess, a 3" stud likely requires an aftermarket solution, and that implies higher strength and more sales for vendors. A rule that said 2? threads beyond lug nut would not solve the above issues
Next time ask about the 2 year seat belt rule.
