It's always something! *UPDATE* and possible fix
#1079374
09/20/11 05:46 PM
09/20/11 05:46 PM
Posts: 20,626 in a cattle trailer down by th...
Guitar Jones
Now I see I have oil running out of the right header on my new engine. Argh! It must have a torn valve seal on an exhaust valve to do that, the pan evac hose is dry. W5's have those deep cups around the valve spring even though they've been drilled to allow oil to drain out it's not going to drain it all. I guess worst case scenario is a guide has come loose, it runs fine though and sounds really good. I guess I'll go pull the cover and take a look...
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: It's always something!
[Re: Guitar Jones]
#1079375
09/20/11 06:25 PM
09/20/11 06:25 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Yeah those spring pockets are deep in the W-5s... I cut a notch out of mine with the die grinder... I'm thinking its more like a guide causing that... but hopefully its just a seal.... but your right... its always something screwing up
[Re: Plymouth340]
#1079378
09/20/11 06:49 PM
09/20/11 06:49 PM
Guitar Jones
i had oil running out of my header on my w-2 motor and it was the head gasket leaking..might be something to look at
How did the head gasket do that? I think first step is I'll pull the header off and see what tube(s) are wet then I'll know what cylinder(s) to look at. Worst case I have extra gaskets except the head gasket.
[Re: emarine01]
#1079382
09/20/11 07:23 PM
09/20/11 07:23 PM
Guitar Jones
Do you run the stock Dia W5 guide? If so the seals dont hold tight and pop off all the time if ya run any kind of valve lift above .650.
Yeah it's a stock guide and the net lift is .698/.714
[Re: Oyvind Mopar]
#1079383
09/20/11 07:26 PM
09/20/11 07:26 PM
Guitar Jones
Same problem on a set of St6 heads, showed up to be leak between valveguide and head. Showed up on one cylinder, but after testing with kerosene, all of them leaked through. I made special spring cups supporting O-rings pressing between head and guide, have not tested yet.... If you look upon the design, there is not much material between valvespringseat and port. Should have been assembled with a sealing compund. My
I've had these heads for a long time without a problem before now. I just had the VJ touched up on the exhaust and 2.08 valves installed in the intakes.
[Re: emarine01]
#1079385
09/20/11 08:33 PM
09/20/11 08:33 PM
Guitar Jones
I pulled the header off and I can see oil running down the stem of #4 exhaust valve. I can see the guides and it hasn't moved. It's dry around the little bit of the guide that sticks through but the stem is wet and you can actually see the trail it has left going down the stem. So it looks good that it's just the seal. If anyone knows a better fitting seal I'd appreciate it. I still have not mastered the search function here. Thanks to all of you for the help.
[Re: MR_P_BODY]
#1079387
09/21/11 10:01 PM
09/21/11 10:01 PM
Guitar Jones
I took the car to work today to fix the leaking rear housing gasket and was telling one of the body guys about my problem. Well he has a mid 10 second small block Camaro (what else is new) and I guess this is pretty common on the Chevys as well. He says he takes some 80 grit sandpaper and scuffs up the outer surface of the guide where the seal goes on and that gives it something to hold on to. Says it works for him so I guess I'll give that a try and see how it goes. I'll let you all know.
[Re: Guitar Jones]
#1079389
09/21/11 10:15 PM
09/21/11 10:15 PM
MR_P_BODY
What I've done in the past is use a small pointed punch on them... give it about a dozen punch marks (it will displace the metal outwards and leave a ridge around it) that give the seal bit
[Re: MR_P_BODY]
#1079390
09/21/11 10:21 PM
09/21/11 10:21 PM
Guitar Jones
That's a good idea too I'm just not sure if I can get in there with the heads on the engine in the car. I really don't want to pull the heads back off.
[Re: MR_P_BODY]
#1079392
09/21/11 10:32 PM
09/21/11 10:32 PM
Guitar Jones
What I used was a piece of 1/8" stainless steel welding tig rod... sharpen it to a point... you want to aim it on a downward angle that way it moves more metal outwards...if you need to sharpen it a couple of times
OK cool, I'll give that a try. Thanks!!
[Re: MR_P_BODY]
#1079395
09/22/11 06:52 AM
09/22/11 06:52 AM
Guitar Jones
OK thanks guys. I'll see what I find when I get the spring off. I'm not going to take it apart until I have all the stuff to put my new rockers on as it's running right now so I can move it around. Thankts to Competition Wedge I should have everything next week to get it done.
I'll keep that in mind roadhazard my head porter gave me some extra seals but I'll see when I get it apart. I'm sure I'll be contacting you in the future as I have an M1 TR and W5 heads so gaskets will be needed eventually. I have some spares but not many left.
