INSTRUMENT PANEL VOLTAGE LIMITER / REGULATOR #1078763
09/19/11 11:32 PM
09/19/11 11:32 PM
Ontario, Canada
GTX fan Offline OP
GTX fan  Offline OP
Ontario, Canada
I need an instrument panel voltage limiter for my '67 Charger. This is the unit that reduces 12vdc to 5vdc to operate the fuel, oil pressure and, temperature gauges. Are OEM units available or do I have to purchase a new printed circuit board unit? Who supplies these, either OEM or reproduction? The reproduction limiter I purchased for this car 2 years ago has quit and I cannot remember where I got it.
Pegged gauges make me
Re: INSTRUMENT PANEL VOLTAGE LIMITER / REGULATOR [Re: GTX fan] #1078764
09/19/11 11:39 PM
09/19/11 11:39 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
There are a bunch of them on Ebay. Here is one:
http://cgi.ebay.com/ebaymotors/NOS-MOPAR...86#ht_500wt_956
Also, Dashworx on this board has a solid state replacement. That is what I used.
Craig
Re: INSTRUMENT PANEL VOLTAGE LIMITER / REGULATOR [Re: denfireguy] #1078765
09/20/11 10:17 AM
09/20/11 10:17 AM
North Carolina
Tadams Offline
Tadams  Offline
North Carolina
I purchased mine from RedFish. He is on the a-bodies site by that name if he isn't on this one. It is a solid state unit, works great and was way less than the one on e-bay.
Re: INSTRUMENT PANEL VOLTAGE LIMITER / REGULATOR [Re: GTX fan] #1078766
09/21/11 10:56 PM
09/21/11 10:56 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
You can make your own. See:
http://www.mopar1.us/instrument.html
Re: INSTRUMENT PANEL VOLTAGE LIMITER / REGULATOR [Re: denfireguy] #1078767
09/21/11 11:51 PM
09/21/11 11:51 PM
Northern California
redwrydr Offline
redwrydr  Offline
Northern California
I used the Dash Worx one also, it is great, and it does have a blinking tiny red light to show you that it is working....it gets my vote.....
Re: INSTRUMENT PANEL VOLTAGE LIMITER / REGULATOR [Re: redwrydr] #1078768
09/22/11 05:06 PM
09/22/11 05:06 PM
Ontario, Canada
GTX fan Offline OP
GTX fan  Offline OP
Ontario, Canada
Thanks folks for your suggestions. I have ordered a new unit from Dash Worx.
Re: INSTRUMENT PANEL VOLTAGE LIMITER / REGULATOR [Re: kentj340] #1078769
09/24/11 12:37 PM
09/24/11 12:37 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Only flaw to that circuit is D1. It protects the $5 regulator from a short circuit. Unfortunately, your $200 harness is not protected. It is still a lot better than using a 7805 three terminal regulator that others use. Maybe if you put a 1 A fuse in front of it to protect the harness it would be better.
Craig
Re: INSTRUMENT PANEL VOLTAGE LIMITER / REGULATOR [Re: redwrydr] #1078770
09/25/11 03:07 AM
09/25/11 03:07 AM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
Wow! Those Dash Worx guys are expensive!
Re: INSTRUMENT PANEL VOLTAGE LIMITER / REGULATOR [Re: lahatte] #1078771
09/25/11 08:35 AM
09/25/11 08:35 AM
Arizona
az426john Offline
az426john  Offline
Arizona
The other option is to make your own as posted by kentj340.
It is not that hard or expensive to do.
For a first timer it is probably $10.00 in parts, $15.00 in equipment, and 2 hours in time. You just bend open the existing case, follow the directions as posted and put the case back together.
Re: INSTRUMENT PANEL VOLTAGE LIMITER / REGULATOR [Re: az426john] #1078772
09/26/11 12:20 AM
09/26/11 12:20 AM
I did that for my 69 charger and the regulator got extremely hot to the touch. Now on the same modification to our challenger, it does not get that hot. Maybe because there is more gauges in the charger than the challenger.
