Re: INSTRUMENT PANEL VOLTAGE LIMITER / REGULATOR
[Re: GTX fan]
#1078764
09/19/11 11:39 PM
09/19/11 11:39 PM
Posts: 1,822 Colorado
denfireguy
Colorado
There are a bunch of them on Ebay. Here is one: http://cgi.ebay.com/ebaymotors/NOS-MOPAR...86#ht_500wt_956Also, Dashworx on this board has a solid state replacement. That is what I used. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: kentj340]
#1078769
09/24/11 12:37 PM
09/24/11 12:37 PM
denfireguy
Colorado
You can make your own. See: http://www.mopar1.us/instrument.html
Only flaw to that circuit is D1. It protects the $5 regulator from a short circuit. Unfortunately, your $200 harness is not protected. It is still a lot better than using a 7805 three terminal regulator that others use. Maybe if you put a 1 A fuse in front of it to protect the harness it would be better. Craig
[Re: az426john]
#1078772
09/26/11 12:20 AM
09/26/11 12:20 AM
The other option is to make your own as posted by kentj340. It is not that hard or expensive to do. For a first timer it is probably $10.00 in parts, $15.00 in equipment, and 2 hours in time. You just bend open the existing case, follow the directions as posted and put the case back together.
I did that for my 69 charger and the regulator got extremely hot to the touch. Now on the same modification to our challenger, it does not get that hot. Maybe because there is more gauges in the charger than the challenger.
