Page 11 of 11 < 1 2 9 10 11
#1076574 - 05/09/12 03:13 PM Re: Post your custom front disc brake setups. [Re: OzHemi]
DarrenB Offline
Loc: QLD Australia
..another:
(we CNC'd billet brackets as they are non-kit calipers. they're actually Wilwood's largest available calliper).
disc's 14.25.
Darren, out of curiosity...what does the engineer have to say about those home made spindles?
Hi Jeff, he doesn't like them. They're actually the Fat Man spindles and the only 2 in drop spindles available at the time. They'd be ok, but I will probably (most definitely) replace them with the one-piece Magnum force units.
Darren Beale
Keith Black, Inc.
#1076575 - 05/09/12 07:28 PM Re: Post your custom front disc brake setups. [Re: DarrenB]
OzHemi Offline
Penguin-hating Ginger
Loc: Garden Grove, CA
I wouldn't have thought he would have liked it. I know the engineer I know of probably would have at it. That is good at least you have another option for it in mind.
Hemi 265's the six to have !
Penguins haunt me.
#1076576 - 08/11/12 04:20 PM Re: Post your custom front disc brake setups. [Re: OzHemi]
OzHemi Offline
I've upgraded mine again...
4 piston brembos are off, and going on are the 8 piston ones.
Before..
And after...
Matching AMG Brembo rear calipers are now on.
Penguins haunt me.
#1076577 - 08/11/12 05:08 PM Re: Post your custom front disc brake setups. [Re: OzHemi]
fuseable Offline
Loc: Midwest
Since this is a brake thread I will throw this in. Will the Wilwood radial on the AR kit fit under a 15" wheel? How does it compare dimensionally to the slider on a 11.75 rotor, ( I mean what would the dimension be from the outer edge of the caliper from center line, or any other way to compare the two setups)?
#1076578 - 08/11/12 05:33 PM Re: Post your custom front disc brake setups. [Re: fuseable]
brads70 Offline
Loc: Ontario,Canada
Here is my creation for 73 c-body spindles and rotors -Viper calipers on my Challenger...
[IMG]http://i651.photobucket.com/albums/uu240/B_Richmond/PDRM0835.jpg[/IMG
25,740 Registered Members
192,892 Topics
Milodon part numbers
by dickdale
02/18/19 07:50 AM
wheel and tire combo
by 70moparmike
02/18/19 06:20 AM
Low oil pressure light?
by gss
02/18/19 12:41 AM
MRM this weekend
by WHITEDART
02/17/19 11:13 PM
