Re: Had To Have My New Crank Turned
[Re: emarine01]
#1076237
09/19/11 08:29 PM
09/19/11 08:29 PM
Posts: 1,532 off the grid
340B5
off the grid
I have finally decided to put an American to work, even if it is only for a couple hours. I'm going to buy a Callies, but it's real hard to spend 300 extra dollars when you don't have to. At least I'll have some piece of mind that I won't be participating in the carnage pics thread.
Yeah, it's got a smallblock.
[Re: 340B5]
#1076238
09/19/11 10:23 PM
09/19/11 10:23 PM
Challenger 1
Cincinnati, Ohio
[Re: MR_P_BODY]
#1076239
09/23/11 12:01 PM
09/23/11 12:01 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Well I got the crank back last night and I put it in this morning... spins nice and free... now I'll check the clearances and if it shows good then I'll start the assembly
[Re: Crizila]
#1076241
09/23/11 01:55 PM
09/23/11 01:55 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
Interesting read. Surprised no one has mentioned the shipper. I would venture to guess that more stuff gets damaged in shipping than you may think. Just because it went from the "factory" to you doesn't mean 10 other people haven't tossed it around in between. Just sent a box of lifters back to Summit a few days ago. They came out of their factory ( individual ) packaging and were all jumbled together in the bottom of the Summit box. Summit's packaging wasn't that swift, but the box looked like it had been dragged behind the UPS truck for a few thousand miles.
Same thing here with some brake parts I ordered. Thrown in a flimsy box with those stupid air bag things and parts all over the place. I was convinced I would be missing something through the hole in the side of the box, luckily not. I agree with the shippers being absolutely horrible, but the packing needs improvement as well.
I can totlaly see a crank being damaged this way.
[Re: POS Dakota]
#1076242
09/23/11 02:17 PM
09/23/11 02:17 PM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
The only aftermarket crank I ever bought was the BPE 4.125 - it was in a double coardboard box, inside was 2 bags of foam - one top and one bottom. It was not OOR when I checked it. I dont know what other manufacturers ship the cranks in but Rod's stuff was packaged right and it helped.
[Re: DJVCuda]
#1076243
09/23/11 02:45 PM
09/23/11 02:45 PM
MR_P_BODY
It measured up good... I set it at .002 and .002 (mains and rods) with .007 end play.... I'm sure not use to 1/16" rings... man do they DRAG... I got 28 ft lbs to turn the assembly, my race stuff takes 18 ft lbs EDIT after playing with it I got the break away torque down to 24 ft lbs... those rings just drag alot
[Re: MR_P_BODY]
#1076244
09/23/11 02:48 PM
09/23/11 02:48 PM
Posts: 3,456 Out West
408strokerdart
Out West
Ft-lbs?
[Re: DJVCuda]
#1076245
09/23/11 02:52 PM
09/23/11 02:52 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I don't know Rob but sounds like he runs his business not have somebody else do it. So if a crank get banged up during shipping it is his dollar. Make sense to package well to avoid unneeded expenses.
[Re: Performance Only]
#1076248
09/23/11 03:26 PM
09/23/11 03:26 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I really dont think it makes any difference if the delivery guy drops the china crank or the american crank they will get bent either way and will cost the same to repair either one! Could someone point me in the direction of the carnage threads with the china cranks that can prove that it was actually the cranks fault. Has anyone ever had to do any work to correct there american made crank?
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#1076249
09/23/11 10:31 PM
09/23/11 10:31 PM
Posts: 20,627 in a cattle trailer down by th...
Guitar Jones
I can't point you in that direction but if my new stroker blows chunks I'm blaming the crank anyway.
Not like it was the fault of the hack that assembled it.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: 340B5]
#1076251
09/24/11 01:56 PM
09/24/11 01:56 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
Last new Crank I bought was in a wooden box with supports for it.It was a Crank Shaft comp crank.Paid 40 bucks for it brand new.Wish I could find deals like that now.Rocky
Chrysler Firepower
Re: Had To Have My New Crank Turned... UPDATE
[Re: MR_P_BODY]
#1076252
09/24/11 04:29 PM
09/24/11 04:29 PM
MR_P_BODY
Well this is what it looks like today... still need to do some clearance work on the valve covers(they hit the rockers at the lip)... I will order up the push rods next week... I'm going to have to use 5/16" push rods because I'm real close to hitting the intake ports... and I need to finish the pan
[Re: DemonDust]
#1076254
09/24/11 05:18 PM
09/24/11 05:18 PM
MR_P_BODY
Looks good Mr P
FWIW..... I have all my cranks checked by my crank guy before I do anything with them.. Just peace of mind
This is the first crank I've had any problem with
[Re: MR_P_BODY]
#1076255
09/24/11 05:29 PM
09/24/11 05:29 PM
Guitar Jones
Looks really good. I had a set of those super expensive valve covers and I sold them because they were sooo heavy.
