Turbo blowing oil (HELP!!) #1076090
09/16/11 09:50 PM
09/16/11 09:50 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
I may have spoke too soon about my chinese GT45. I took the car out today for a short trip to my buddies shop and after parking it for alittle I noticed oil on the ground. Long story short, I pulled the elbow right at the turbo and it is full of oil. I thought maybe my drain it backing it up into the compressor but It leaves the turbo in a 180 fitting and falls about 2in. to the fuel pump block off where it dumps and is 5/8 hose all the way. Could the seals be bad already? Is my drain insufficient?
Re: Turbo blowing oil (HELP!!) [Re: SLOW67] #1076091
09/16/11 10:19 PM
09/16/11 10:19 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
A 180 degree fitting? As in "oil going in any direction but down?" You cant have any loops or sags in the return line. If the oil isn't going down hill all the time, it will backup like that. Correct the routing and you shouldn't have any problems. Continuing to use it that way will carbon up the seals on the turbine side though.
Re: Turbo blowing oil (HELP!!) [Re: TRENDZ] #1076092
09/16/11 10:46 PM
09/16/11 10:46 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
I comes out of the turbo and goes straight down and 180's under the turbo like a U but it is downhill the whole way. I pulled my blockoff plate at the fuel pump and the gasket was partially blocking the hole so I fixed that. It may have been the problem but you do have me concerned about my 180 fitting coming out
Re: Turbo blowing oil (HELP!!) [Re: SLOW67] #1076093
09/17/11 12:47 AM
09/17/11 12:47 AM
Virginia
2
2k1AmberR/T Offline
2k1AmberR/T  Offline
Virginia
If it goes down and then does a 180* U meaning it starts trying to flow upward...that's horrible. That would have ruined seals in a cheap chinese ebay turbo or a high dollar precision unit, it doesn't matter. You can't do that.
Re: Turbo blowing oil (HELP!!) [Re: 2k1AmberR/T] #1076094
09/17/11 01:37 AM
09/17/11 01:37 AM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
Geeez,
here we go with the "Cheap" chinese thing again!!
First question is,
Did you put the oil restrictor in your feed line??? I purchased the fitting with the restictor cast in it. Your turbo is probably getting too much oil pressure and pushing oil past the seals. As stated above, the oil return must have a straight shot to the oil pan....
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: Turbo blowing oil (HELP!!) [Re: CUUDAK] #1076095
09/17/11 01:45 AM
09/17/11 01:45 AM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
Here is the "Restricted" oil feed that I am talking about,
http://cgi.ebay.com/ebaymotors/TURBO-OIL...=item43a40d1c74
Re: Turbo blowing oil (HELP!!) [Re: CUUDAK] #1076096
09/17/11 03:27 AM
09/17/11 03:27 AM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
Yes it has an oil restrictor, no it doesn't "U" back uphill. See attachment maybe it will clear up the confusion
Re: Turbo blowing oil (HELP!!) [Re: SLOW67] #1076097
09/17/11 03:39 AM
09/17/11 03:39 AM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
If your are going from the driverside all the way to the passenger side of the block this could be the issue. Oil may be backing up in the return. My return is -12an and is really short due to the turbo being on the same side as the fuel pump mounting location. I too used this area for my return but it is at a 45 from the turbo to the fuel pump blockoff plate. My return is only about 16 inches long. It has a -12an 45 out of the turbo about 45 degrees down to a -12an 45 into the blockoff plate.
Initial start has not happened yet so I cannot confirm mine is working properly but I bet it will be ok! Mine is a different snail than yours. I chose the B/W S480 to be safe but seen several "Ebay" turbos screaming down the track without failure!!
Re: Turbo blowing oil (HELP!!) [Re: CUUDAK] #1076098
09/17/11 09:21 AM
09/17/11 09:21 AM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
From the drawing you posted the oil drain is coming out of the side of the turbo instead of out the bottom....a very big problem if that is the case.
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: Turbo blowing oil (HELP!!) [Re: instigator] #1076099
09/17/11 01:40 PM
09/17/11 01:40 PM
Virginia
2
2k1AmberR/T Offline
2k1AmberR/T  Offline
Virginia
That's exactly what it looks like. You need to clock the center section 90* so the oil return shoots straight to the ground. You also need to just tap your oil pan (at the top) close to the turbo and shoot your oil return line straight down to the pan. Going across the whole engine horizontally like that isn't good either. Try to make the entire return line no less than 45* at any point, that way it is always traveling downward toward the pan no matter what. I'd suggest tapping the pan on the drivers side near the turbo. Sure it sucks to pull the engine and tap the pan...but it doesn't suck as much as ruining a turbo every 50 miles.
Re: Turbo blowing oil (HELP!!) [Re: SLOW67] #1076100
09/18/11 01:50 AM
09/18/11 01:50 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Your turbo is probably fine, for now. Keep running it and it'll be carboned up.
Oil should enter through a restrictor. I run restrictors off Mazda RX-7s. Other guys shove .040" Holley jets in their lines.
There are no positive oil seals (like a wheel bearing seal) on a turbo. They spin waaaay too fast for that kind of thing. The drag from the seal would kill the response and once it did get up to speed the turbo would melt the seal. They spin more than 100,000 rpm in many installations.
Do you have any idea what happens to oil when it's sprayed on a shaft spinning 100,000 rpm? Foam happens. Think of shaving cream. How do you drain shaving cream? Quick answer: you don't.
The oil returns to the engine by the magic of gravity. Your feed line is a tiny little thing and the return is a big fat hose (1/2" minimum, 5/8" is great). For gravity to do it's job the hose has to be down hill all the way. If there's anything remotely close to a horizontal part of that line the shaving cream will sit there and not drain. it backs up the return line and makes a mess by finding leaks to escape or flooding the turbo. If it gets past those not-really-a-seal shaft seals your car will smoke like a Cheech and Chong movie.
One of my return lines got tweaked into a near horizontal position. The engine would pump out a smoke screen that would drift across an intersection until the oil was up to temperature.
Oil in is always restricted and always on top.
Oil out is always big and fat going downhill all the way.
If you can't reroute the oil line into a downhill position you have two options:
1) Put it into the oil pan ABOVE the level of the oil in the pan.
2) Install a small reservoir to catch the oil and a pump to push it out.
Live and learn. You've done pretty well so far. One little detail got past you. Fix it and move on.
- Stu Harmon
Re: Turbo blowing oil (HELP!!) [Re: feets] #1076101
09/18/11 12:16 PM
09/18/11 12:16 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
Ok so I reclocked the housing so the drain would face my return point instead of horizontal and Now I've got about 4" of fall at a 45o angle going down. I drove it alittle bit this morning and it seems to have cleared up but I think I will tap the pan soon anyway just in case.
Re: Turbo blowing oil (HELP!!) [Re: SLOW67] #1076102
09/18/11 12:59 PM
09/18/11 12:59 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If it's working, don't mess with it. Leave it alone.
- Stu Harmon
Re: Turbo blowing oil (HELP!!) [Re: feets] #1076103
09/18/11 03:54 PM
09/18/11 03:54 PM
IL
furious70 Offline
furious70  Offline
IL
from what I've seen on tmf, the prevailing thought now is to try no restrictors and only if you smoke put them in. I did not put them in mine, though I do have the fittings should I need them.
70 Sport Fury
68 Charger
69 Coronet
72 RR
