Stamped steel BB rocker arm ratio? #107544
08/19/08 10:57 PM
08/19/08 10:57 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
I know this has been covered before, but along time ago. What is the average ratio of the Mopar stamped steel rockers. Would it be worth it to go to a true 1.5 roller rocker? Or would a 1.6 rocker be better. The engine in question is my 383 with blended 346 heads, shaved 0.030 and a 3 angle valve job - headers and the Eddy Performer RPM intake, 750 Holley. The XE262H cam has a 462/470 lift. I'll be doing a few passes at the track, but mostly cruising with my foot in it quite often.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Stamped steel BB rocker arm ratio? [Re: Junky] #107545
08/20/08 01:39 AM
08/20/08 01:39 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yea the factory stamped steel rockers say they are 1.5 but I have heard they are more like 1.4. That said I used them for years on the old 383 that was in my sons Dart. It had the MP .484 cam and it ran as fast as 12.31 with the stock rockers on it. They dont work to bad but I did use rocker shaft shims to set the lifter preload to .020. Ron
Re: Stamped steel BB rocker arm ratio? [Re: Junky] #107546
08/20/08 01:54 AM
08/20/08 01:54 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Check out the tech article from Hughes Engines:
http://www.hughesengines.com/general/techArticleDetail.asp?articleID=1000046
Besides the bad ratios and non-adjustability, the pushrod can break through rocker if your using stiffer valve springs.
Re: Stamped steel BB rocker arm ratio? [Re: 451Mopar] #107547
08/20/08 02:10 PM
08/20/08 02:10 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Good info about rockers. What I'd like to know is what higher lift does for the power band. Does it raise the RPM level of the power band? Does it raise shift points? Does it add torque, and if so, does the torque come in sooner or later in the RPM range? I'm going to replace the stock rockers, I just need to know if I should go with a higher lift. What about running 1.6 rockers vs 1.5?
Re: Stamped steel BB rocker arm ratio? [Re: Junky] #107548
08/20/08 02:49 PM
08/20/08 02:49 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
shouldn't alter the powerband, just raise it, IF your heads could benefit from increased lift. most OEM mopar heads peak flow in the .450-.5" lift range without porting, so odds are you'll see minimal butt dyno gain just from the rocker switch...
2017 Grand Cherokee Overland
Re: Stamped steel BB rocker arm ratio? [Re: patrick] #107549
08/20/08 03:04 PM
08/20/08 03:04 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
You're saying my 346 heads that have been blended and have a 3 angle valve job wouldn't benefit with increased lift above .450?
Right now with the .462 (calculated at 1.5 ratio) cam lift on the intake valve, with stamped steel rockers at 1.4 ratio, the actual lift is .430, not .462. So I need a "real' 1.5 rocker to get the full potential out of my heads. Right?
If my heads can't do anything with a valve lift above .450, I'm wondering what would be the best cam for my 383.
This cam and rocker ratio stuff can fry a few brain cells.
Re: Stamped steel BB rocker arm ratio? [Re: Junky] #107550
08/20/08 03:34 PM
08/20/08 03:34 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I would go with a doctile iron rocker at a 1.5. A roller will do nothing for you on you set up but drain your pocket book faster. Unless you are racing this and want every little bit out of it I doubt that you will notice much difference.
Re: Stamped steel BB rocker arm ratio? [Re: Junky] #107551
08/20/08 03:41 PM
08/20/08 03:41 PM
Upper Midwest
Black_Sheep Offline
Black_Sheep  Offline
Upper Midwest
Stock stamped rockers are supposed to be 1.5:1 but I recall reading somewhere that they are actually closer to 1.4...
'69 Plymouth GTX
See you on the street...
Re: Stamped steel BB rocker arm ratio? [Re: Black_Sheep] #107552
08/20/08 04:16 PM
08/20/08 04:16 PM
organ
maximum entropy Offline
organ
measure them for yourself. i've measured jillions of 'em, and they've all been almost exactly 1.5. ok, maybe not jillions, but some.
Re: Stamped steel BB rocker arm ratio? [Re: maximum entropy] #107553
08/20/08 05:38 PM
08/20/08 05:38 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Maybe I should concentrate a better cam.
Re: Stamped steel BB rocker arm ratio? [Re: maximum entropy] #107554
08/20/08 05:43 PM
08/20/08 05:43 PM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
I use the stock rockers as I don't use a lot of spring pressure. The stock six-pack springs are about as crazy as I get. Over the years I've measured a lot of rockers also and they are anything but consistent. I have never worried about ratio, just the lift at the valve for an individual rocker arm all other factors being equal. I use a solid lifter, an adustable pushrod, a relatively weak spring, a dial on the valve retainer, and an actual cam to go through batches of rocker arms. I try to split them up into two groups that have equivalent lifts. The higher lifts go on the exhaust and the lower lifts on the intake. Always worked for me. As a side note, this entire procedure is one Racer Brown had since the mid 70's.
Re: Stamped steel BB rocker arm ratio? [Re: maximum entropy] #107555
08/20/08 07:12 PM
08/20/08 07:12 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Correct, measure your own. I have measured several, 1.47 to 1.48.
Re: Stamped steel BB rocker arm ratio? [Re: BSB67] #107556
08/20/08 07:45 PM
08/20/08 07:45 PM
usa
lewtot184 Online content
lewtot184  Online Content
usa
the stamped steels i've measured using a solid tappet, adjustable push rod, and checking valve spring were 1.5. all 1.5 adjustables i've measured, using the above mentioned method, were 1.6. all 1.6's i've measured were 1.65-1.66. going from a true 1.5 ratio to a true 1.6 will add about 5-7 degrees duration at .200 lobe lift, nearly nothing at .050 lobe lift; on the average flat tappet cam. and thats my story and i'm sticking to it.
Re: Stamped steel BB rocker arm ratio? [Re: lewtot184] #107557
08/20/08 08:34 PM
08/20/08 08:34 PM
Upper Midwest
Upper Midwest
You want to see a surprising change in your measurement. Get rid of the solid lifter, Take hyd. lifter and shim the plunger to the pre load that you will be using then measure the liftratio. You will be surprised and the difference due to depth of the push rod in the lifter and angle change. You will find that unless using solid lifter on a solid cam with the rocker adjusted to spec. you will be very inaccurtate on a hydraulic cam using the solid lifter.
Re: Stamped steel BB rocker arm ratio? [Re: MoparforLife] #107558
08/21/08 10:17 AM
08/21/08 10:17 AM
dogdays Offline
dogdays  Offline
Done that a few times, have you?
I remember John Lyons (ran a Camaro superstock years ago at the strip near Fargo) sitting at the parts counter at the store in Grand Forks patiently going through box after box of plugs getting sets indexed for his heads. There's more tedium in racing that is let on.....
R.
Re: Stamped steel BB rocker arm ratio? [Re: dogdays] #107559
08/21/08 10:24 AM
08/21/08 10:24 AM
Upper Midwest
Upper Midwest
Would I have brought it up if I hadn't.
Re: Stamped steel BB rocker arm ratio? [Re: MoparforLife] #107560
08/21/08 11:04 AM
08/21/08 11:04 AM
North Dakota
North Dakota
Depends what you want. If you are trying to get an absolute lift number at the valve you are absolutely correct. If you just want to compare a batch of rockers against each other, it doesn't really matter.
Re: Stamped steel BB rocker arm ratio? [Re: 6PakBee] #107561
08/21/08 11:12 AM
08/21/08 11:12 AM
Upper Midwest
Upper Midwest
And I am/was under the impression that it is max lift that is in question being the comparison of 1.5 - 1.6 rockers was used in the original post. Yes, if getting a uniform set of rockers was the issue it wouldn't be a big deal as to which lifters to use. But the lift change do to angle because of push rod depth in the lifter is significant.
