Re: Request: Parts Catalog 1969-1971 edition(s) [Re: cudaized] #1075114
09/16/11 12:24 PM
09/16/11 12:24 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Ola,
I would guess that 2808142 is a lower level part number to the assembly 3417412.
The Bill Of Material for 3417412 might look like this:
3417412 Barracuda Tail Panel Assembly
2808142 Panel
280xxxx License Plate Bucket
0999xxx Square Weld Nuts (2)
1111xxx Sealant
I have an NOS Challenger panel and I'll check it for a similair number but I'll guess that it does not have one since there no additional items needed to make the part.
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: cudaized] #1075115
09/16/11 12:32 PM
09/16/11 12:32 PM
western australia
1cuda Offline
1cuda  Offline
western australia
i`ve got an nos tail panel that looks exactly like that one-trouble is-i won`t be able to get numbers off it for a while...it`s on the other side of the country. i`ll see if i can get a friend to look at it. will send you a pm over the next week or two.
all the best
frank.
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: 1cuda] #1075116
09/16/11 05:59 PM
09/16/11 05:59 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I dont have a parts book in front of me and having owned a few of these NOS many years ago, I can't recall if they had the holes pre-stamped for the rear molding plastic retainers or did they all come NOS requiring those holes to be drilled for a Cuda model.
If there were the two versions of these panels, one for Barracuda and one for Cuda, it may account for a separate part number for each.
Ola...yours does not appear to have the holes.
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: cudaized] #1075117
09/17/11 03:55 PM
09/17/11 03:55 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Ola,
I checked my May 1970 parts book and it shows the 341 part number and not the 280. The 280 part number is also not in the reference section.
I also checked my NOS Challenger panel and it has BOTH the number stamped and the stenciled on. They match 2963261
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: Morty426] #1075118
09/17/11 06:44 PM
09/17/11 06:44 PM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
Ola,
2808142 Panel
1111xxx Sealant
Chris,
That is the most plausible explanation. Thank you for your insight.
I thought about this scenario [sub assembly] but did not have the resources (i.e. engineering drawing) to confirm my suspicions.
The license plate section does not have any part numbers stamped. Just: SS-46 1 (?) and the nuts and sealant???
It makes the most sences (and a lot of things in the world today don't). Thank you.
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: 1cuda] #1075119
09/17/11 06:46 PM
09/17/11 06:46 PM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
frank.
Thank you frank. Looking forward to the info.
How's your 71 V doing?
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: mccannix] #1075120
09/17/11 06:48 PM
09/17/11 06:48 PM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
Terry,
No Sir. No holes. Just a sloppy primer job!
I haven't seen any with the holes pre-drilled. Hummm.
Re: Request: Parts Catalog 1969-1971 edition(s) [Re: Morty426] #1075121
09/17/11 06:53 PM
09/17/11 06:53 PM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
The sub assembly idea for the Barracuda panel, is making more and more sense.
Ola
