68 RR fender mounted turn signals don't work. #1074463
09/13/11 05:08 PM
09/13/11 05:08 PM
NC
rc68rr Offline OP
rc68rr  Offline OP
NC
Is there a bulb that can be replaced & how do you get them apart.It has power(flashing) with a test lite to the turn signal mounted to the fender. Thanks to all.
Re: 68 RR fender mounted turn signals don't work. [Re: rc68rr] #1074464
09/13/11 05:14 PM
09/13/11 05:14 PM
Utah
E
Eagleone1983 Offline
E
Utah
There is a tiny bulb that can be replaced. The method to do so is by sticking either a screwdriver or quarter in the slot on the lense and turn. If it is an old lense then use a quarter for sure and be super careful. More than likely though if they are old lenses they will crack.
Re: 68 RR fender mounted turn signals don't work. [Re: Eagleone1983] #1074465
09/13/11 05:25 PM
09/13/11 05:25 PM
NC
rc68rr Offline OP
rc68rr  Offline OP
NC
If they crack (the lens) does anyone sell replacements. Thanks
Re: 68 RR fender mounted turn signals don't work. [Re: rc68rr] #1074466
09/13/11 06:08 PM
09/13/11 06:08 PM
Iowa - a member of the rustbel...
Birdturd Offline
Birdturd  Offline
They repop the lens so you should be ok there
Re: 68 RR fender mounted turn signals don't work. [Re: rc68rr] #1074467
09/14/11 07:42 AM
09/14/11 07:42 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
www.krusinmoons.com sells the lenses
Re: 68 RR fender mounted turn signals don't work. [Re: Pntastar69] #1074468
09/14/11 08:42 AM
09/14/11 08:42 AM
New Kent, Va.
bobbyb Offline
bobbyb  Offline
New Kent, Va.
If you get new bulbs and it still doesn't work, it might not be grounded. The turn signal itself needs to have a good ground between the fender and turn signal housing.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
Re: 68 RR fender mounted turn signals don't work. [Re: bobbyb] #1074469
09/15/11 06:13 PM
09/15/11 06:13 PM
NC
rc68rr Offline OP
rc68rr  Offline OP
NC
Does anyone know the number for the bulb ? Thanks for all the help.
Re: 68 RR fender mounted turn signals don't work. [Re: rc68rr] #1074470
09/15/11 07:25 PM
09/15/11 07:25 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
MAYBE THIS WELL HELP?
http://genet.gelighting.com/LightProduct...;CATEGORY=Lamps
70 Challenger Convertible 340 six pak CLONE?
70 Duster real FM3 car
65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
Re: 68 RR fender mounted turn signals don't work. [Re: rc68rr] #1074471
09/15/11 07:35 PM
09/15/11 07:35 PM
P
Pntastar69 Offline
Pntastar69  Offline
P
www.krusinmoons.com sells the lenses and the bulbs too.
Re: 68 RR fender mounted turn signals don't work. [Re: rc68rr] #1074472
09/15/11 07:41 PM
09/15/11 07:41 PM
Yonkers N.Y
GTSfanatic Offline
GTSfanatic  Offline
Yonkers N.Y
330
1968 Dart GTS 340 Auto...White, Red Int
Re: 68 RR fender mounted turn signals don't work. [Re: GTSfanatic] #1074473
09/17/11 12:17 AM
09/17/11 12:17 AM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
You need to remove the turn signal from the fender. There's a set screw underneath that holds the lens. If you try to turn it, it'll break.
