msd timing #1073912
09/12/11 07:32 PM
09/12/11 07:32 PM
Tennessee
rrp92 Offline OP
rrp92  Offline OP
Tennessee
I have done some searches and still cannot figure this timing deal out with msd's charts. I have the msd pro billet distributor in a 499" RB. I am trying to go with 38 degrees total all in by 2500-3000 and lowest possible initial timing so it will start. Which spring and bushing combination will achieve this?
Re: msd timing [Re: rrp92] #1073913
09/12/11 07:54 PM
09/12/11 07:54 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i had a 493rb with the same dist. i just locked it out, 37 total, street- strip. never had any problems starting. no detonation. 13mpg staying out of it. stay safe, seeya.
Re: msd timing [Re: rrp92] #1073914
09/12/11 08:28 PM
09/12/11 08:28 PM
WA
JD Dart Offline
JD Dart  Offline
WA
Two sliver light weight springs all in by 2500-3000. The bushing depends on how much intial you want. So set it to 20 intial and put in the black bushing gives you total 38.
Red 28
Sliver 25
blue 21
Black 18
best so far 8.53 @ 158.59 MPH 60'1.240
