Reverse dash lamp and back up lights #1073887
09/12/11 04:44 PM
09/12/11 04:44 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
69 Coronet 4 speed.When I put it into reverse the dash lamp and back up lights are on,but when I take my hand off the shifter they go out.If I hold it in reverse they work fine.Is there an adjustment to tighten this up?Do I need a new back up light switch?
Thanks in advance
Re: Reverse dash lamp and back up lights [Re: 5carguy] #1073888
09/12/11 11:03 PM
09/12/11 11:03 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Double check your 4 speed linkage adjustment..
The internal reverse lever mechanism needs to push hard up against switch..
Sometimes just a slight adjustment lengthening the reverse rod will do it..
Just my $0.02...
