Alky carb ?????????????????? #1073296
09/11/11 07:40 PM
09/11/11 07:40 PM
TN
65racer Offline OP
2009 IHRA World Champion
65racer  Offline OP
TN
Need a little advice from the carb experts, I changed
over this weekend to alky, in my car for some testing
purposes, mostly everything went as planned, with the
exception of 1 problem that croped up, the car will
not do a decent burnout, it pops, and bangs in the
box, like it is on a two step, the car leaves the line
as it
should, but the water box problem has me perplexed,
I did not take my gas stuff with me to change back if
there was a problem, so I didn't get to see if it was
something about the car or the carb, I borrowed the
carb from a friend that ran it on his car, until it
lost the engine a while back, I replaced the pump gaskets.
and cleaned it good, it cranks and idles great, revs great, but
I figured the carb was lean on the front 2 barrels,
being the reason it was popping in the water box, but turning the
air screws out made no difference with the problem, so if someone
has any suggestions I am all ears, the car ran fine last weekend
on gas, so I don't really suspect that there is something
wrong with the car, and to finish up, the car didn't run a
bit faster on alky than it did on gas, can lay time slips
side by side and there is no difference in the et's and mph's
go figure, I have always heard that if you were set up right
on gas going to alky there would be very little gain, but the
car does run a bit cooler.
Re: Alky carb ?????????????????? [Re: 65racer] #1073297
09/11/11 08:02 PM
09/11/11 08:02 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
What's the fuel pressure during the burnout?
Re: Alky carb ?????????????????? [Re: 65racer] #1073298
09/11/11 08:07 PM
09/11/11 08:07 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Whats the throttle position when performing your burn out? Some of those carbs arent the cleanest running at part throttle.
What I did when I was running injection was add a extra 3 step, limiter. Its easy to over rev a dragster in the box, killing valve springs. I had a 5500 or 6K chip in that side, flip the switch and lay it on the wood.
Also what kind of fuel filer are you running... It needs to be a stainless mesh type filter for sure....
Dont go crazy with plug gap too.... Alky motors dont like wide plug gaps...... about .035-.038 is max..
Hope this helps ya..
Re: Alky carb ?????????????????? [Re: DavidDean] #1073299
09/11/11 08:08 PM
09/11/11 08:08 PM
TN
65racer Offline OP
65racer  Offline OP
TN
7 lbs, I know the way I have it set up
is not the optimal way to run with alky,
but there are a lot of racers doing it
the way I am doing, this was just for
testing purposes, to see if I want
to run it next season.
Re: Alky carb ?????????????????? [Re: 65racer] #1073300
09/11/11 08:42 PM
09/11/11 08:42 PM
ill
dennismopar73 Offline
ill
heres what i learned and picked up from guys ,, if the fuel system is close on gas , the switch to alk, is at best 10-2 tenth mostly for cooling advantage, and some hp gains,, i have seen 3-4 tenths pick up,
idono carb to carb change you did, no info there given?
i know the guys are told to look at mph, and heat gain in the 1/4 -1/8 mile, if it gets colder down track, its lean,, if it gets warmer by 20 deg its to 'fat' , sometimes diffrent heat rang of plugs are also needed to maximize the effect and burn of alk, timming may also come into play, useually couple * less timming ?
it is alittle diffrent game getting the carb set and fine tunning,
oo 7 # most likley not enough
Re: Alky carb ?????????????????? [Re: dennismopar73] #1073301
09/11/11 09:58 PM
09/11/11 09:58 PM
South Bend, Indiana
mistress Offline
mistress  Offline
South Bend, Indiana
[i know the guys are told to look at mph, and heat gain in the 1/4 -1/8 mile, if it gets colder down track, its lean,, if it gets warmer by 20 deg its to 'fat'
You got it backwards. too fat and temp will drop down track, too lean will get hotter.
Re: Alky carb ?????????????????? [Re: mistress] #1073302
09/11/11 10:45 PM
09/11/11 10:45 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I am having to jet up now myself. I was running 165/170 and could never get it hotter with the 440/ 1050 dominator. I stuck a 520 cube under the same system and now it stays at 200. I figure I am really lean, which makes it run hotter. Plug gap is .026 and timing at 36*
Re: Alky carb ?????????????????? [Re: Mopar-Al] #1073303
09/11/11 11:15 PM
09/11/11 11:15 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
Davey you are to lean a MOPAR likes a lot of ALC but could be the carb you should pick up at least 5 hundreds or one tenth and run a lot cooler i have 188 jets in my 1050 RUPERT said i could need more jetting but sounds like a carb problem ? I called Brad and he said it could be a carb problem call Rupert he can fix it.
Re: Alky carb ?????????????????? [Re: mistress] #1073304
09/11/11 11:38 PM
09/11/11 11:38 PM
ill
ill
corrected sorry
Re: Alky carb ?????????????????? [Re: dennismopar73] #1073305
09/12/11 08:53 PM
09/12/11 08:53 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
Here`s Rupert number 1-931-372-9142
