Challenger Grill Restoration #1073200
09/11/11 06:03 PM
09/11/11 06:03 PM
Texas
missu34 Offline OP
missu34  Offline OP
Texas
Reading throught some of the forums, I still have some questions concerning grill restoration for a non rt/ta 70 Challenger.
1. The argent paint seems darker than the light argent paint used on rally wheels for year 1970. The grill paint is the same correct?? If not what paint should I be using?? Can I just mask and spray over the existing argent paint? It's in above average condition but has some minor imperfections.
2. Any ideas how to spruce up the honeycomb section without dismantling the entire grill? One member suggested using acid based a/c coil cleaner but upon checking at Home Depot all of the coil clearners were non acid based. I liked this option because he stated you just sprayed the cleaner on that section of the grill and then just hosed it off.
I can't afford a $500+ professional grill restoration so I'm open to all suggestions.
Thanks.
Re: Challenger Grill Restoration [Re: missu34] #1073201
09/11/11 09:23 PM
09/11/11 09:23 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
You should read this post. I think it will be very helpful to you.
70 Challenger Grille Resto
65 Barracuda
70 Challenger
Re: Challenger Grill Restoration [Re: jrwoodjoe] #1073202
09/11/11 11:35 PM
09/11/11 11:35 PM
Texas
missu34 Offline OP
missu34  Offline OP
Texas
Helpful, yes but it still doesn't address my key questions.... can anyone help with specific's especially with my question concerning the argent paint?
I must comment... Troy's rt grill is superb.
Re: Challenger Grill Restoration [Re: missu34] #1073203
09/12/11 10:55 AM
09/12/11 10:55 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
When I did the grille in my former 70 challenger 340
I used the argent paint from Frank Badalson, problem is I don't remember for sure but I think I used the 70 cuda shaker bubble paint. ( must find old can around here somewhere)
Which ever one it was I had to tint it ever so slightly to make it match the original point on my grille
egg crate portion I used a flat dark grey rattle can paint
