Turbo size #1072770
09/10/11 06:09 PM
09/10/11 06:09 PM
northeast texas
strokin73cuda Offline OP
northeast texas
Will a pair of h1e turbos work good on anything?
496 stroker,Indy srs , new best 6.87 @ 98 1.46 60'
Re: Turbo size [Re: strokin73cuda] #1072771
09/12/11 08:53 PM
09/12/11 08:53 PM
northeast texas
northeast texas
How bout on a stock 360 with j heads in an 83 4x4. I have 2 of these turbos and want to try them on something to get a little experience about them. This is my spare truck so it don't need alot of boost I would like to keep it halfway dependable but with a little more power in the mud and on the street would be nice. Thanks
Re: Turbo size [Re: strokin73cuda] #1072772
09/12/11 09:52 PM
09/12/11 09:52 PM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
http://www.theturboforums.com/search.php...Findex.php#1108
Plenty to read here!!
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: Turbo size [Re: CUUDAK] #1072773
09/13/11 05:33 AM
09/13/11 05:33 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
buy a copy of MAXIMUN BOOST by Corky Bell./
while not race oriented it will explain the fundamentals.
I found it explains the functions and relationship of the various parts
home of the
Sox and Martin Hemi Duster
Re: Turbo size [Re: strokin73cuda] #1072774
09/14/11 01:12 AM
09/14/11 01:12 AM
Las Vegas NV
Revhard Offline
Revhard  Offline
Las Vegas NV
That would be fine. looks like t4 flange. those look like they may give a back pressure issiue so I would say just dont go crazy. Ive got a 6g72 and using a triple k out of a volks on only two cylinders no waste gate so its open. That one is putting out 4lbs which is all I need.
Re: Turbo size [Re: strokin73cuda] #1072775
09/15/11 12:13 AM
09/15/11 12:13 AM
Clovis,NM
Dartman318 Offline
Dartman318  Offline
Clovis,NM
The important things to measure would be the intake Millimeter and the Exhaust Outlet Millimeter.'
Then to figure out which housings the exhaust housings were and what size engine to size them to.
Should be easy enough to size them...bust out the Millimeter Ruler!
But I'll save you the effort and tell you No...Unless your messing with a 3.0-4.0 V6
Re: Turbo size [Re: Dartman318] #1072776
09/16/11 07:52 PM
09/16/11 07:52 PM
northeast texas
northeast texas
Best I can tell 60mm com. Side and 64 exhaust side and I do have 2 of these for the 360 if needed. T-4 flange.
Re: Turbo size [Re: strokin73cuda] #1072777
09/18/11 11:38 PM
09/18/11 11:38 PM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
Might want to measure them but I am pretty sure they are T3 flanged... I might be thinking of the H1C though.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
