Re: Which is the right water pump for my 383 Roadrunner
[Re: JohnRR]
#1072753
08/17/12 03:24 PM
08/17/12 03:24 PM
Posts: 5,439 So Cal
Sinitro
So Cal
What about the distributor and timing curve... A close friend and his 383 was overheating badly up to 225, he changed water pumps, added a shroud... Still a problem... I checked his Mopar performance distributor, he had 14 degrees mechanical advance...
I reset it to 10 degrees mechanical advance, set initial @ 15 degrees and fired it up.. It ran @ 190 degrees and is doing very well in our 105 degree SoCal heat wave..
Check the basics... Mopar built a pretty robust engine and cooling system..
Just my $0.02...
Is this correct ? That would only be 25 TOTAL, I can see it running even hotter ?????
10 degrees in the distributor is x2 @ the crank + 15 degrees (initial).. 20 + 15=35 degrees total @ the crank. IMHO... One can run a little more total advance but the BB wedges don't really run that much better with more advance.
Just my $0.02...
[Re: Sinitro]
#1072754
08/17/12 05:04 PM
08/17/12 05:04 PM
Posts: 74,962 U.S.S.A.
JohnRR
U.S.S.A.
Just my $0.02...
Just my $0.02...
Thanks for finishing that and some people in Michigan would beg to differ on the total timing for big block wedges ...
