Re: First time With drag radials..... HELP!!!
[Re: DemonDust]
#1072363
09/09/11 09:26 PM
09/09/11 09:26 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
17-20 psi, stiffen up your rear shocks, loose on front
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 440CIVIC]
#1072369
09/10/11 10:10 AM
09/10/11 10:10 AM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I just went through this last weekend. Im sure all cars are different but I couldnt get mine to hook up. Everyone on here said 17-20 lbs. It spun terrible with that much air and once they start spinning you might as well lift because they dont recover like a slick. I started talking to other people in staging with some really fast cars and they said 13-14 lbs. Dropped em down to 13.5 and they hooked awsome. My car ran the best 60' ever with a 275 60 e.t. street radial over a 28 14.50 q.t. pro. I would start at 14 and go from there.
67' charger 499 RB
10.57 at 127
[Re: DemonDust]
#1072374
09/10/11 12:57 PM
09/10/11 12:57 PM
dragram440
bigfork mn
Is that a leaf spring car? If it doesnt hook good on the first pass drop it down to 13 and I bet it sticks!What size tires do you have and what size wheels? What dos the car run?
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#1072377
09/10/11 02:53 PM
09/10/11 02:53 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Yeah ss springs right now. Hopefulley ladder before the ice drags.
I'm running 325-50-15 on a 10 inch rim MT et drag radial.
This will be the first time on asphalt with this engine. On ice in the 660 best was 7.049 And 109 mph hoping to drop below 10 but don't think it will happen with this setup.
[Re: DemonDust]
#1072378
09/10/11 03:39 PM
09/10/11 03:39 PM
dragram440
bigfork mn
I think your car will hook no prob with those tires. I ran a 275-60 which only has a 9" tread with junk 40 year old suspesion and ran 1.49 60' with a 10.63 e.t. @125 mph. I dont think you will have any probs hooking unless you are launching it at 6500.
67' charger 499 RB
10.57 at 127
[Re: DemonDust]
#1072380
09/11/11 01:45 AM
09/11/11 01:45 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
I found the Hoosier DR hooks the best, The BFGs are #3 on the big 3 DR scale from feedback on them, they will hook, but if its a stick car it might be tricky. I can vouch that the Hoosier DRs hook "hard", even on crappy track prep in a stick car, With my MTs on my dart they were a bit finiky on the bottle on a so-so prep, I had my extention too tight & they would just skate untill i let off then got back into it, On the 3 sets of MTs i ran in 3 different cars the best pressure was 17 lbs. "cold", anything over 19 was a wash, but every car is different, I'd start with 18 cold & see how it does, & don't need a john force burnout for them to hook, just get them hot quick & pull to the line.
