Are 318 Magnum pistons different from 318 LA?
#1071459
09/08/11 04:19 PM
09/08/11 04:19 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I'm in the middle of my little budget 318 build and I've hit a snag. The 95 Magnum 318 short block I picked up has a small crack in one of the cylinders. I already bought a new Mahle ring set for the Magnum pistons. I have a 75 318 in immaculate condition needing nothing more than rings, bearings and resealed. My question is, can I use the Magnum pistons in the LA block for a little compression bump, or are they basically the same except for the metric size rings. I was going to use the K6900 cam and Magnum heads from my current 360 in the 318 LA. I don't have the spare dough to have the Magnum block bored and buy new pistons, so I was looking to do it on the cheap. Or should I stick with the 75 318 pistons?
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
Re: Are 318 Magnum pistons different from 318 LA?
[Re: 69L78Nova]
#1071460
09/08/11 05:15 PM
09/08/11 05:15 PM
Posts: 31 Two Harbors, MN
chrgr340
Two Harbors, MN
I don't recall what the exact difference is, but I just read somewhere a day or two ago that LA and Magnum pistons are different. I'd probably stick with the LAs.
1972 Dodge Charger - F7, Rallye pkg, 340, A833 2007 Dodge Charger R/T R&T - 12sec daily beater 1999 Dodge Dakota R/T - M1, cam, heads, T56 swap 1997 Dodge Dakota - 318, NV3500, 3.92 Sure Grip
[Re: Moparnut426]
#1071462
09/08/11 05:47 PM
09/08/11 05:47 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
If the Magnum bore is the same size as the LA's bore(both virgin, both +.020,etc), you should be able to swap the magnum crank, balancer, rods and pistons over to the LA block and keep moving. Use the Magnum head bolts to bolt the Magnum heads on the LA also.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: Moparnut426]
#1071463
09/08/11 05:48 PM
09/08/11 05:48 PM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Whoops, I'm sorry. I should have been more clear. I mean I was thinking of using the Magnum pistons AND rods in the LA engine. Would that work, or is the rod different on the crank end as well? The only reason I ask is because the magnum engines are rated as being 9 to 1, and the LA is 8.5 to 1. I don't know if the magnum heads on an LA block would boost compression, or if the magnum chambers are around the same size as the old 70s 318 LA heads.
[Re: 69L78Nova]
#1071465
09/08/11 05:53 PM
09/08/11 05:53 PM
RapidRobert
360 piston ~584 grams pin 154.6 rings 56.6 comp height 1.590". Mag piston 470, pin 134, rings 40 grams CH 1.662". As said th LA rod small end is 2 wide but can b narrowed but that'd b $$$ plus then you'd need to weigh all the pieces 4 the balance factor & you're doing a budget build. Not sure what I'd do but that's what I could come up w
[Re: RapidRobert]
#1071466
09/08/11 06:02 PM
09/08/11 06:02 PM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Could I use the whole 1995 rotating assembly in the 1975 block? Crank, rods, pistons, balanced and flexplate? I would just like to use the newer stuff if I can.
I wasn't aware the old 70s 318 two barrel heads were open chamber. I guess ya learn something new every day!
[Re: RapidRobert]
#1071467
09/08/11 06:10 PM
09/08/11 06:10 PM
Posts: 3,344 Central TX
roe
Central TX
wouldn't the magnum heads on his LA 318 give him a nice bump in compression, especially with a thinner head gasket. If the LA is in such nice condition why not re-ring, new bearings, magnum heads and go with the LA 318?
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: roe]
#1071468
09/08/11 06:13 PM
09/08/11 06:13 PM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
That's what I planned to do. I wasn't sure if the compression height of the Magnum pistons was the same as the LA pistons. If the difference is minimal or not worth it, ill just run the LA stuff
[Re: 69L78Nova]
#1071469
09/08/11 06:28 PM
09/08/11 06:28 PM
roe
Central TX
Im definately no expert on this. Somebody a few posts back said that you can swap over the entire rotating assembly. If that true what king of issues could he run into? Wouldn't that be like slightly stroking the 318 to about 349 or so? Would he have to start worrying about clearance issues with those pistons/heads in the 318?
[Re: roe]
#1071470
09/08/11 06:50 PM
09/08/11 06:50 PM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
No, both are 318s. One Magnum, one LA
[Re: GO_Fish]
#1071472
09/09/11 01:06 AM
09/09/11 01:06 AM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Ok, good to know. I already have the complete Magnum top end on my 78 360, I would just transfer the heads, manifold, carb, and K6900 cam/lifters into the 318. Looks like that's what ill do.
[Re: 69L78Nova]
#1071473
09/09/11 10:01 AM
09/09/11 10:01 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
yes, and is what I'd do.
compression height is marginally higher than the older pistons, and the metric ring packages are the big differences between LA and magnum 318.
[Re: roe]
#1071476
09/09/11 08:57 PM
09/09/11 08:57 PM
Posts: 1,445 Sterling Heights, Michigan 483...
daniel_depetro
Supposedly the Magnum engines have a lighter rotating assembly weight too.
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
[Re: daniel_depetro]
#1071477
09/09/11 10:22 PM
09/09/11 10:22 PM
GO_Fish
Maryland
That is true (lighter Magnum rods and pistons). That is why the whole Magnum rotating assembly needs to move to the LA block to maintain correct balance without a trip to the machine shop for custom balancing.
Scott B.
[Re: GO_Fish]
#1071478
09/10/11 12:13 AM
09/10/11 12:13 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
The differance in piston height is about .080 witch will make a nice bump in compression. However just swapping magnum heads onto a 318 LA with magnum heads will not yield you as much compression as a factory 318 magnum because the 318 magnum had a lower deck height also by about .015.
[Re: HotRodDave]
#1071479
09/10/11 12:18 AM
09/10/11 12:18 AM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Yeah I'm just going to swap the whole magnum rotating assembly into the LA block. Plus, I already bought the rings and they weren't cheap. Does it matter what year bearings I use since the cranks interchange? Every listing I've seen lists pre-80, and 80-newer for rod/main bearings
[Re: HotRodDave]
#1071480
09/10/11 12:20 AM
09/10/11 12:20 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I know nothing about the differences but I'll throw this out... Most late model engines have gone to a one piece full circle rear main seal... For that to work the back of the crankshaft is different from an earlier style engine...
[Re: 1_WILD_RT]
#1071481
09/10/11 12:21 AM
09/10/11 12:21 AM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
They are both 2-piece seal blocks
[Re: 1_WILD_RT]
#1071483
09/10/11 11:23 AM
09/10/11 11:23 AM
HotRodDave
Kalispell Mt.
The only bearings that may make a differance is the thrust bearing, or the rear main bearing, the flange on the thrust bearing may be different (bigger diameter)and I think one bearing fits all but the other will not fit in the other block so if your thrust bearing goes in your block it is good. The rear main bearing one was wider than the other and again I don't remember the year break or witch one is universal.
[Re: HotRodDave]
#1071484
09/10/11 11:37 AM
09/10/11 11:37 AM
daniel_depetro
Interesting... Is there a difference in deck heights between: 1971-88 LA360 1989-92 roller camshaft LA360 1993-2002 5.9l Magnum ?!?!?!
[Re: HotRodDave]
#1071485
09/10/11 11:57 AM
09/10/11 11:57 AM
Posts: 15,487 Florida
scratchnfotraction
I didnt think of the thrust bearing..but IIRc all the magnum engine used the 360 size rear main bearing or main cap size and 360 oil pan.
not sure if the bearing would have changed or the main cap size for the pan seal
something you might want to look at before the swap starts
[Re: scratchnfotraction]
#1071488
09/11/11 02:36 PM
09/11/11 02:36 PM
HotRodDave
Kalispell Mt.
The 318 and 360 magnums both have slightly shorter deck heights than the LAs did. TBI and carb had one deck height and the MPI magnum had the shorter one, I am not sure why they made one ity bity change like that Main bearing diameter on ALL 318 polys, LA, and magnums are the same includeing the rear main. The differance in the magnum and earlier ones is the thickness of the cap, it was changed so you could use one pan for both motors.
