440 a518 swap info #107139
08/19/08 01:02 AM
08/19/08 01:02 AM
Anonymous OP
Anonymous OP
I know this has been beaten up as a topic but no realy good info on the adapter plates them selfs is out there. I dont trust a bell that bolts to the pump it self. So I am just wondering if anyone has pictures of the adapter plate bolted to a big block and or how it works. I got a rough idea and I am thinking about making my own adapter plate I will be doing a build on this tranny and may ask more questions as I do It.
Re: 440 a518 swap info #107140
08/19/08 01:09 AM
08/19/08 01:09 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have a JVX adaptor plate. It is 1/2" thick and has a machined adaptor for the crank along with a new flexplate that has the starter gear attatched to it. There was a Hot Rod article about 10+ years ago on this swap, and this is the adaptor they used.
Re: 440 a518 swap info [Re: 451Mopar] #107141
08/19/08 01:24 AM
08/19/08 01:24 AM
Anonymous OP
Anonymous OP
Yeh hey thanks for the quick reply they never gave much infor on the plate it self. So half inch hu? is it aluminum? I could quite possibly machine it my self. I build my own intake and efi with a megasquirt kit. I will probably have the ecu control the overdrive. I have a 92 a518 non lockup and 2 727 bigblock trans and another 440 block to fit everything with.
Re: 440 a518 swap info #107142
08/19/08 03:31 AM
08/19/08 03:31 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I think the adaptor was machined from a big sized plate, and it uses unique bolts that have about 1/4" thick head and screw in with an allen wrench.
The plate re-locates the starter position, so a notch has to be cut in the transmission bellhousing for the starter.
The adaptor kit was pricy, I think around $500!
Here are some related links:
http://www.hotrod.com/howto/43323_mopar_overdrive_transmission_swap/index.html
http://jvxracing.com/jvxcatalog.pdf
Let me know how the megasquirt works out, I might try that in the future...
Re: 440 a518 swap info [Re: 451Mopar] #107143
08/19/08 11:04 AM
08/19/08 11:04 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Courtesy of a Moparts member... https://board.moparts.org/ubbthreads/show...e=1#Post3453311
Bolt on adpt... but seem to work well... Best of Moparts
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: 440 a518 swap info [Re: R70RUNNER] #107144
08/19/08 11:08 AM
08/19/08 11:08 AM
Anonymous OP
Anonymous OP
Yeh thanks I belive I have read all the posts I can find on here and other places on the net and I think the bell that bolts to the pump will cause my pump bolts to work loose as time goes on. I am making some serious power just want to have perfact gearing for the 1/4 and a overdrive to cruise in.
Re: 440 a518 swap info #107145
08/19/08 11:12 AM
08/19/08 11:12 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Noticed your looking for an adapt plate.. not the bell
I'd be interested to see how a 518 stands up for you behind real power... Think it's been tried with results
Good luck
Re: 440 a518 swap info #107146
08/19/08 11:20 AM
08/19/08 11:20 AM
Anonymous OP
Anonymous OP
Does anyone know if the 727 big block tranny torque converter fits a 727 small block tranny?
Re: 440 a518 swap info [Re: 451Mopar] #107147
08/19/08 11:30 AM
08/19/08 11:30 AM
Anonymous OP
Anonymous OP
So the bolts that thread though the plate to the origanl tranny are counter sunk? I love the megasquirt it has endless capibilitys but kinda like the overdrive conversion its not for every one its alot of work and alot of learning. But a big part of the reason I did it was to learn I have about 3000 miles on the megasquirt and still working out bugs But I built it with 4 throtle bodies staged and a staged 16 injector system as well. I just installed launch control and hooked it to the brake lights for now so when you push the breaks and push the gas it hits a soft rev then a rev limiter and you can basicly pin the gas and once the brake light shuts off you are gone! I have it running the 3 electric fans and electric water pump. set lean at light cruise and full perfact 12.7 at wide open. To much to talk about it has been about 2 years of work so far but I love it there is nothing cooler then building something fast then tring it out!
Re: 440 a518 swap info #107148
08/19/08 07:13 PM
08/19/08 07:13 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The bolts that go to the block are counter sunk into the plate, and then the other side has counter sunk bolts that thred into the plate to make like a stud mounting setup, so the trans goes over the bolts that are threded into the front of the plate and then nuts hold the trans to the adaptor plate.
727 small block/big block torque converters fit the same and can be interchanged if the ballance/bolt pattern are the same. I stock 518 is a bit weak, but there are alot of aftermarket parts to beef them up.
Re: 440 a518 swap info [Re: 451Mopar] #107149
08/19/08 07:20 PM
08/19/08 07:20 PM
Anonymous OP
Anonymous OP
Hey thanks I am planing a good build for it and I think I will get a bigblock stall as long as I can get the starter to line up.
Re: 440 a518 swap info #107150
08/19/08 07:48 PM
08/19/08 07:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
How many instances were reported of pump bolts coming loose? Credibility of reporters?
Remember the Clutchflite? Loose pump bolts were never a problem that I heard of and they were used on some insane horsepower installations.
Re: 440 a518 swap info [Re: John_Kunkel] #107151
08/19/08 11:39 PM
08/19/08 11:39 PM
Anonymous OP
Anonymous OP
I havent herd of any coming loose, but also havent herd of much for miles on any of the bell users, and not to mention how much power do they make with there cars driving styles? I like to drive hard and put alot of miles on. I am just trying to be cautious. How hard are they launching? twisting on the pump bolts? I would have more faith if a couple guys with big power big blocks had some good runs down the 1/4 and lots of miles on the highway.
Re: 440 a518 swap info #107152
08/19/08 11:58 PM
08/19/08 11:58 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
I've got the Ultrabell/440 combo. Haven't cut the bell off yet. What's your reasoning for the pump bolts coming loose? I've worked on jet engines held together with 1/4" fasteners torqued to 65in-lbs. They don't come loose. The flex plate to torque converter uses those four little bolts, and the driveshaft has those four 1/4" bolts with all the engine power going through them, and they don't come loose or break. I don't think the pump bolts have that much going through them. Isn't the Ultrabell most often used on race cars for safety reasons?
Re: 440 a518 swap info [Re: 375inStroke] #107153
08/20/08 12:20 PM
08/20/08 12:20 PM
Anonymous OP
Anonymous OP
I am not trying to be a jerk just being cautious and want to see some results before I jumped into a ulta bell. But as for the drive shaft bolts they dont take the stress of the twisting force the yolk does, where as the pump bolts on a ultra bell take all the twisting between the tranny and engine and hold the engine up in the rear and the tranny up in the front.
Re: 440 a518 swap info #107154
08/20/08 12:45 PM
08/20/08 12:45 PM
dogdays Offline
dogdays  Offline
First of all, eggs have yolks, while u-joints have YOKES.
Secondly, the bolts should not be loaded in shear. They should be tightened sufficiently that the friction between the two surfaces prevents slippage. This depends on material matchup, radius and clamping force. It's the same as mounting a wheel on a hub.
I'd say the crank to flexplate hub is more highly stressed.
R.
Re: 440 a518 swap info [Re: dogdays] #107155
08/20/08 11:19 PM
08/20/08 11:19 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The ultrabell is a nice item. They just were not avaliable 10 years ago when I got the JVX adaptor.
A friend of mine is running the Ultrabell to connect his 470 cid stroker to a 904. He just got the car together a month ago and has not raced it yet, so I can't say how it will hold up?
Re: 440 a518 swap info [Re: 451Mopar] #107156
08/21/08 06:02 AM
08/21/08 06:02 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Pat has adapters at SMR transmission.
Another thing is according to Pat the 518 is very inefficient. Moving to a 518 will take about 1 second of your quarter mile time...If performance matters to you.
Re: 440 a518 swap info [Re: The Shadow] #107157
08/21/08 08:16 AM
08/21/08 08:16 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Less efficient than a 727?
Clair
Re: 440 a518 swap info [Re: Clair_Davis] #107158
08/21/08 09:32 AM
08/21/08 09:32 AM
Seattle, WA
3
375inStroke Offline
375inStroke  Offline
3
Seattle, WA
I've heard about truck racers that are loosing a second in the quarter too switching to a 727. A full second, though? Really?
