Re: 440 a518 swap info [Re: 375inStroke] #107159
08/21/08 09:51 AM
08/21/08 09:51 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
I got an Ultra bell coming some time this week. I'm going to use mine in my tow rig behind a 446 c.i. mill.
Moparlee
Re: 440 a518 swap info [Re: The Shadow] #107160
08/21/08 11:19 AM
08/21/08 11:19 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Pat has adapters at SMR transmission.
Another thing is according to Pat the 518 is very inefficient. Moving to a 518 will take about 1 second of your quarter mile time...If performance matters to you.
considering the OD is just another 727 planet, I really find this hard to believe....
2017 Grand Cherokee Overland
Re: 440 a518 swap info [Re: The Shadow] #107161
08/21/08 12:13 PM
08/21/08 12:13 PM
Anonymous OP
Anonymous OP
performance does matter to me but I hate driving a 2000 mile road trip the putting the car up on stands and pulling the diff out and changing from the 2.76 gears I have to the 3.91s that are perfact for me for the 1/4 and driving for the weekend then changing back to drive home not to mention having the 3rd member roll around in the trunk and smash out my 1/4 pannels. Thoses guys might think you will loose 1 second in the 1/4 but PROVE IT! I will be going from the 3.23 gears I have now that arent that good for the 1/4 and suck on the highway reving 2800 at 60mph to 3.91 that are perfact for the 1/4 and will rev 2350 on the high way in overdrive. I took my overdrive compleatly apart last night and found the overdrive section is heavy like ~20 pounds and that is spinning weight (which on an inertia dyno will show less horsepower but wont make a difference on a steady load dyno both taking readings from the rear wheels) As for the "you should be driving in you peak tourque for best mileage" topic (this topic will probably come up soon) it is also not true simply because the engine is more powerfull then the car needs. I could understand it being true with a engine designed for the car to be delivering the best gas milage. So in conclusion if you build the whole car to use the overdrive properly it can show gains in milage and performance!
Re: 440 a518 swap info [Re: The Shadow] #107162
08/21/08 12:16 PM
08/21/08 12:16 PM
Anonymous OP
Anonymous OP
Show me the tests!
Re: 440 a518 swap info #107163
08/21/08 09:25 PM
08/21/08 09:25 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Fellas as this is a forum for information and I'm not the tranny expert this is how the story goes. I was just talking with Pat at SMR and we got on the subject of the 518. He is the one who said it will lose the second so if you don't take my word call the trans man himself. Maybe he can convince you.
http://www.smrtrans.com/
Re: 440 a518 swap info [Re: The Shadow] #107164
08/22/08 01:19 AM
08/22/08 01:19 AM
Anonymous OP
Anonymous OP
What i am tring to say is the tranny they used as a three speed, was it geared the same? Did it have the same stall speed? Did they use the same rear endgears? If they used the same rear end gears then were they pulling full rpm throught the traps? If so then with those gears they will be at a pretty hi rpm on the highway at 60-70mile per hour. If I geard mine to run the best in the 1/4 I would use 3.91 rear end gears. If I used the 3.91 gears for a 1/4 mile run with a 3 speed and a 518 I would be willing to bet the 3 speed 727 would turn a quicker 1/4 time because the car would weigh less and there would be less pasasidic drag in the tranny. But With the 3.91s I would rev 3400 rpm at 60mph in 3rd with a 727 Or I can just use overdrive and cruse home or instead I could pull over to swap out to a 2.76 that still revs higher at 60 then the 518 with 3.91s and would more than likely burn more gas on the way home. Then if I was one of those people who has a instance that I wanted to have some fun on the way home I could have a faster car to do it with because I still have the low 1st 2nd and 3rd that the 3.91s give me.
Re: 440 a518 swap info #107165
08/22/08 07:55 AM
08/22/08 07:55 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
I didn't get any pictures of it yet, but it did come in yesterday. I'll be cutting the old one off this weekend.
Moparlee
Re: 440 a518 swap info [Re: Robbins] #107166
08/22/08 12:29 PM
08/22/08 12:29 PM
Anonymous OP
Anonymous OP
How much did you pay who did you order it from? I live in canada so shipping becomes a pain in the but ups rapes us pour canadians!
Re: 440 a518 swap info #107167
08/22/08 12:38 PM
08/22/08 12:38 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Moparlee
Re: 440 a518 swap info #107168
08/25/08 01:37 PM
08/25/08 01:37 PM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
[quote How much did you pay who did you order it from? I live in canada so shipping becomes a pain in the but ups rapes us pour canadians!
Go to: www.racewithjw.com they list some distributors in Canada
Re: 440 a518 swap info [Re: Robbins] #107169
08/25/08 02:03 PM
08/25/08 02:03 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Get some good pics as your cutting it down please. That is the only part I'm squemish about. I figure I'll cut mine down wrong!
Re: 440 a518 swap info [Re: Jwilli500] #107170
08/26/08 08:47 AM
08/26/08 08:47 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Well no, but I was tripping on it too. Really though it was too easy. I did take some pictures, but I don't have them where I can post them yet. Sorry.
I'm working right now on welding the shift linkage tab and the kick down tab on the bell housing and drilling the new holes in the frame for the OD crossmember.
Moparlee
Re: 440 a518 swap info [Re: The Shadow] #107171
08/26/08 10:29 AM
08/26/08 10:29 AM
Middle of the US
V
Verga Offline
Verga  Offline
V
Middle of the US
I dont care who said it. That is total nonsense.
So you are saying it takes 100 more HP to turn a 518?
"Im supercharged, might explode in your face"
Re: 440 a518 swap info [Re: Verga] #107172
08/26/08 11:19 AM
08/26/08 11:19 AM
Anonymous OP
Anonymous OP
I am almost done building my adapter plate. I decided to build one from steal so I can keep it thinner. I will weld the studs in for the tranny and use short head bolts to bolt the plate to the engine and machine a bit into the tranny housing for the bolt heads that thread into the engine. I figured out you have to use the 727 position for the starter. And I lucked out and got the 360 magnum tranny with the high stall. It is a 10.75" converter that just might stall out were I need which is ~2400 rpm to still be streatable. Mine is a non lockup so thats what I will have to limit my stall at for now. It should rev at 2350 with 3.91 gears my 26" tires and about 200 rpm slip at 60mph like I had with the 12" 727 converter. I will take pictures tonight. I also figured out I have to cut the welds on the starter gear and slide it back the distance of the tranny adapter plate towards the engine on the converter and I will need to space the tourque converter back the same distance from the flex plate as well. The further you can keep the tranny forward the easer it will fit in the tunnel. I have a transgo shift reprogramer kit and a super master rebuild kit coming with red eagle clutches so I can squeeze in 5 clutches instead of 4. Should be fun!
Re: 440 a518 swap info #107173
08/27/08 08:27 PM
08/27/08 08:27 PM
Anonymous OP
Anonymous OP
up date just knoticed I needed a small bolt patter flex plate but that wasnt a problem I just did a google search and found one for 9.95 from 440 source online. it is on its way.
Re: 440 a518 swap info [Re: Robbins] #107174
08/28/08 01:39 PM
08/28/08 01:39 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
What did you wind up cutting the case with? That Ultrabell is heavy considering it's aluminum! It is very thick though.
Re: 440 a518 swap info [Re: Jwilli500] #107175
08/28/08 11:30 PM
08/28/08 11:30 PM
Anonymous OP
Anonymous OP
You can buy a milling disc at a welding supply shop that will mount on your angle grinder. It comes with carbide teath on it and looks like a mini skill saw blade. It will cut through the aluminum like butter but be extreamly carefull it will take your arm off like nothing as well. Just make sure you are cutting in the right direction/angle so it doesnt kickback.
Re: 440 a518 swap info [Re: Jwilli500] #107176
08/29/08 07:19 AM
08/29/08 07:19 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Sawsaw and right angle grinder with one of those plastic disk with little sand paper squares on it. Hope that makes sense. Yes the ultra bell is think.
Moparlee
Re: 440 a518 swap info [Re: Robbins] #107177
08/31/08 06:12 AM
08/31/08 06:12 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
