Charcoal Canister - How to Replace foam pad #1068821
09/04/11 09:16 AM
09/04/11 09:16 AM
Ohio
C_B5 Offline OP
C_B5  Offline OP
Ohio
What is the procedure to disassemble the charcoal canister to replace the foam element?
Did not see it in the factory manual, if anyone has the pages showing details please post. This is for a 1972 model though believe they are all the same
Re: Charcoal Canister - How to Replace foam pad [Re: C_B5] #1068822
09/06/11 02:04 PM
09/06/11 02:04 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I don't think it comes apart. All you can do is replace the fiberglass filter at the bottom.
Re: Charcoal Canister - How to Replace foam pad [Re: C_B5] #1068823
09/06/11 05:03 PM
09/06/11 05:03 PM
Berwyn, IL
Moparlar Offline
Moparlar  Offline
Berwyn, IL
I believe the filter just tucks under that crossbar on the bottom.
Larry
Re: Charcoal Canister - How to Replace foam pad [Re: Moparlar] #1068824
09/06/11 05:05 PM
09/06/11 05:05 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Yes, the filter just tucks in the bottom but the OP wants to take the whole thing apart and replace the charcole inside. I don't think it comes apart like that.
Re: Charcoal Canister - How to Replace foam pad [Re: burdar] #1068825
09/06/11 07:24 PM
09/06/11 07:24 PM
Omaha
road Offline
road  Offline
Omaha
I had and extra one and tried to figure out how to take it apart. It was glued together and ended up in quite a few pieces.
Re: Charcoal Canister - How to Replace foam pad [Re: road] #1068826
09/06/11 09:58 PM
09/06/11 09:58 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Does the grille twist off?
It's listed in the "Lubrication and Maintenance" section of my '77 van FSM, but the later cannister appears to be a different design:
Re: Charcoal Canister - How to Replace foam pad [Re: In_The_Pink] #1068827
09/06/11 11:26 PM
09/06/11 11:26 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I think the bottom of the early style canisters unscrewed originally. It looks like they were glued in though. Not to mension the years of heat cycles has warped the plastic somewhat.
