FBO Ignition system toubleshooting
#1068570
09/03/11 06:11 PM
09/03/11 06:11 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
I have less than 500 miles on the system. It just died in the garage from driving around town, lucky I know. Now no fire. The dizzy has 365 ohms.....ignition 1 and 2 at the ballast is good. The ballast has .9 ohms.
The coil is hot on both sides(12 volts) though, this doesn't seem right to me. Isn't the negative side of the coil supposed to blink with a test light when spinning over. It's just as hot as the positive side even just sitting not turning the motor over.
Also when key is on I have less than 4 volts coming from the ignition box to the dizzy, not sure if that's correct or not.
Any help would be appreciative, thanks.
Moparlee
Re: FBO Ignition system toubleshooting
[Re: mikemee1331]
#1068572
09/03/11 08:55 PM
09/03/11 08:55 PM
Robbins
Joplin, MO USA
It's an older (a couple of years ago now) system I guess, cause the website shows some different boxes now. Mine looks like the regular mopar style brain box, but it's black. I got the box, coil & ballast with it.
Moparlee
[Re: Robbins]
#1068574
09/03/11 11:10 PM
09/03/11 11:10 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Make sure the ignition module is grounded well. It needs to be screwed down tite, metal-to-metal.. Especially its rear side... Also double check the reluctor gap should be 0.008 using a brass feeler gauge... Just my $0.02...
[Re: mikemee1331]
#1068577
09/04/11 09:06 AM
09/04/11 09:06 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
Don told me that his original ECU could not handle 12v and that is why he had it redesigned with the new 12v coil. I ran his old ECU with another brand 12v coil (no ballast) on the street for about 6 months with no issue. That ECU "might" last for a while with 12v on it. I bought his new 12v ECU/Coil but I only have about 4 weeks driving time on them, but so far no problems.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#1068578
09/04/11 10:14 AM
09/04/11 10:14 AM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
good info here and do check what Sinitro suggested.
[Re: gtsdude]
#1068580
09/04/11 11:42 AM
09/04/11 11:42 AM
mikemee1331
bethlehem pa
I had same issue with my ballast blowing, try an MSD ballast, have never blew one of those yet, been 5 years now.
his ignition is all matched. your suggestion is all well and good if the ohms are the same ballast to ballast.
[Re: mikemee1331]
#1068581
09/04/11 11:49 AM
09/04/11 11:49 AM
Robbins
Joplin, MO USA
I haven't had a chance to go outside this morning, but it doesn't seem wrong to have 12 volt on the negative side of the coil?
Moparlee
[Re: 469runner]
#1068584
09/04/11 02:55 PM
09/04/11 02:55 PM
Posts: 74,948 U.S.S.A.
JohnRR
U.S.S.A.
That box is probably bad. I had the same issue and replaced the box. I barely had 2000 miles on this set up. That stuff is all hype. It won't produce one more horsepower. "Yap, yap, yap,my stuff is better than everyones elses, all made in the USA." Yeah, tell that to the guy that spent 200 dollars on your stuff and is now sitting on the side of the road. OK, rant off. Just get a mopar performance setup. You'll be happier.
And carry a spare ECU and a ballast ....
[Re: gtsdude]
#1068588
09/04/11 11:50 PM
09/04/11 11:50 PM
Robbins
Joplin, MO USA
Thanks guys, I'll be calling him and see what he says next week.
Moparlee
[Re: Robbins]
#1068589
09/06/11 05:52 PM
09/06/11 05:52 PM
Robbins
Joplin, MO USA
Well...........I called him. I'm out on warranty by a day or two. But he did give some info....I shouldn't have 12 volt with the key in the on position like I do.
Well as soon as I plug into the ballast I get 12 volts, I'm not sure how or why. Unplug the pink wires from the ballast and no voltage. My blue wire is supposed to have 12 volts, but the pink two wires on the other side in the run position shouldn't have until you turn the key to ignition two. When I ohm the resister it shows 1.2 ohms.
What I'm missing here?
[Re: Ronnman]
#1068590
09/06/11 06:26 PM
09/06/11 06:26 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
You have 12 volts on both terminals because its is not being grounded by the ECU. The ECU may not be receiving a signal from the distributor module or the ECU has a problem, maybe grounding as mentioned, or is bad. If you disconnect the distributor 2 prong connector and tap the male connect on the harness side that goes to the ECU, that should trigger the ECU to fire the coil.
You are reading the "dead end" 12V on both terminals because there is no current flow. If no current flow through a resistor (coil) the voltage drop will be zero, thus the presence of 12V on each terminal. Ron
That is 100% correct. To add if the ballast was bad you would not have voltage to the coil as it goes thru the ballast in the run position. And you said it read .9 ohms. Do the test where you touch the male end of the dist harness to ground and see if it sparks. If it dont you need the ECU and it it does its not seeing the dist signal. Ron
[Re: 383man]
#1068591
09/06/11 06:34 PM
09/06/11 06:34 PM
mikemee1331
bethlehem pa
what he said and did you find out what ohm the ballast is supposed to be? did you make sure the ECU is grounded?
[Re: mikemee1331]
#1068592
09/06/11 07:40 PM
09/06/11 07:40 PM
Robbins
Joplin, MO USA
Ok, I was trying to learn to trouble shoot with the ohm meter and look at stuff. Don at FBO I was talking again this afternoon and done some more trouble shooting and we ended up trying another box that I had on my dad's van that wasn't too old. It fired right up so it was the box. Once running the positive side of the coil had 6 volts on it. Why the RC read differently than my shotbed I don't know.......both work so.
Anyway he cut me a deal on one of his newer units & sent it out the door today. Thanks Don.
Thanks everybody for your feedback.
Moparlee
[Re: mikemee1331]
#1068595
09/06/11 08:18 PM
09/06/11 08:18 PM
Robbins
Joplin, MO USA
Well, it (ballast) worked with a different brain box. So.........I'm not sure what it should ohm out to. Today is was reading 1.2 where the other day it was .9 This is my Fluke meter.
The newer system doesn't require a ballast and he says to tie them together, I would probably do a nice jumper so I can go to regular system on the fly if need to.
Just so you know he says that you can run the older box with the older and the newer style for 30 minutes or so to get home if need be.
Moparlee
[Re: Robbins]
#1068598
09/07/11 07:44 AM
09/07/11 07:44 AM
YO7_A66
Indiana
""i think you should call him and make sure the coil he sold you is a true 12v or is internally ballasted (is that a word?)""
The new FBO coil #HR688 is a true 12v coil. (Reference, the coil can be mounted in any direction, per Don.) It looks just like the old FBO coil (size and shape) except for the writing on the coil is different. The old coil/ECU could handle 12v for a short time period (Don designed it this way for his drag car) and the new coil/ECU was designed for 12v all the time. I know for a fact that the new coil and the old coil are not the same unit. I started emailing Don in the Spring of 2010 to see if he was going to come out with a 12v coil and he had already been testing one for a while. Last fall (2010) when I wanted to swap to a 12v coil, I emailed him again about his 12v coil and it was still not ready. Then this past Spring I emailed him again and it was being tested but still not ready. This past Summer he started selling them and I now have one and I have been running it now for about 6 weeks. Don's ignition parts may be a little more expensive, but Don sells a very nice Mopar ignition system.
[Re: mikemee1331]
#1068601
09/25/11 08:32 AM
09/25/11 08:32 AM
Robbins
Joplin, MO USA
I haven't called him yet, but the new box is on and working here are a couple of pictures of the newer box.
Moparlee
[Re: NachoRT74]
#1068607
09/25/11 11:07 PM
09/25/11 11:07 PM
Robbins
Joplin, MO USA
.....that's just messed up. Who ever posted that on that site......thanks for the heads up.
Moparlee
[Re: Robbins]
#1068608
09/26/11 12:04 AM
09/26/11 12:04 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
maybe IS TRUE the GM HEI module inside is nothing like a stock unit and really a Performance piece, but still on that way!!! I still can get a Performance GM kind HEI unit ( Moroso or Accel like I have foudn on the ebay ) and built into a stock original box like I posted there
[Re: NachoRT74]
#1068611
09/26/11 07:40 AM
09/26/11 07:40 AM
Posts: 11,076 Berlin, N.J.
abodyjoe
Berlin, N.J.
pretty box but REALLY EXPENSIVE for what it looks is built inside:
https://board.moparts.org/ubbthreads/show...e=3#Post6838807
( check the link I posted there )
interesting. i bought this set up http://designed2drive.com/ to put HEI on my car. still haven't gotten around to installing it.. its a lot cheaper then that FBO box...
According to Don it's not, and it doesn't operate like one either, it just happens to look similar to one, but you would have to ask him yourself for further explination or perhaps a better description. He also stated that most of the cost for the unit is tied up in the billet Mopar style box, and not the part that's in it.
who knows what it really is. lol
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt. www.MoparMisfits.com
[Re: abodyjoe]
#1068612
09/26/11 06:35 PM
09/26/11 06:35 PM
Robbins
Joplin, MO USA
The funny thing is that I almost took the back off and looked at it. Oh, well it's water under the bridge now.
Thanks again Nacho for posting that other post for us.
Moparlee
[Re: Robbins]
#1068613
10/06/11 10:43 PM
10/06/11 10:43 PM
Robbins
Joplin, MO USA
Well, I'm having issues already. Once warmed up it doesn't want to start, no fire. I'm going to call him tomorrow.
Joe, I had thought about buying the one that you posted a long time ago when I first seen it. The first time I think that I seen anything like it....I was at an early Hemi guy's place...Kent Redd.....he had one under a plate behind the carb on a 271 Dodge Hemi. "Just run four wires" he said.
Other than the box is a little expensive in my opinion, I like the idea of it looking stock and not having to rewire....seeings I just done a ton of rewiring under the hood on this thing. It looks like the aftermarket has tons of these modules...looks like MSD has one now that looks like a stock GM piece.
I've got a pix of the back of this that I'll pm to anybody if they are wanting to see what it looks like.
Just to be clear, I never was posting anything in this thread to bash Don! I was just posting a question on trouble shooting ideas. Which I got some thanks Moparts.
Moparlee
