Lunati Voodoo cam (60403) for a 340/416 stroker
#106829
08/18/08 12:45 PM
08/18/08 12:45 PM
Posts: 1,142 Tucson, AZ
cruzin
Tucson, AZ
Is anyone using the Lunati Voodoo series 60403 cam (226/234 & 494-513 lift) in a 340/416 stroker or similiar setup? The cam is for a 4" cast crank, 10:1, E-heads w/1.5 rockers, Airgap/750 carb, headers 2.5" full exhaust, 3500lb. E-body, auto (2000-2400 stall), and 3.91, street car. Looking for something streetable and don't need anything radical.
A buddy of mine has the next step down (i.e. 60402) cam in a very similiar spec'd 360/408 stroker motor, in a 3700 lbs, B-body which I'm very impressed by.
The Lunati cam rep. spec. out this cam for my application and I'm interested in what others think.
Re: Lunati Voodoo cam (60403) for a 340/416 stroker
[Re: cruzin]
#106830
08/18/08 12:56 PM
08/18/08 12:56 PM
i suppose you want us to search out the cam specs???? or would it be more productive of you posted them?
[Re: cruzin]
#106831
08/18/08 12:57 PM
08/18/08 12:57 PM
Posts: 8,144 Arkansas
340727dart
Arkansas
I've got that cam in my 340. It's a great street cam. But, I would think with a stroker it is too small.
Your life is not my fault. My life is none of your business.
Speech is free only if you agree with those in control.
[Re: dogdays]
#106835
08/18/08 03:22 PM
08/18/08 03:22 PM
Posts: 16,122 Grand Haven, MI
patrick
Grand Haven, MI
should be a great, torquey street motor. I'd expect it to idle pretty smooth (say, 15-17" Hg at ~800-850 RPM) and make a boatload of torque. I'd swagger the HP peak is going to be around 5000 RPM
[Re: 69Cuda340S]
#106837
08/23/08 04:04 AM
08/23/08 04:04 AM
Posts: 571 Beaverton, OR, USA
Alikazam
super gas
super gas
Beaverton, OR, USA
I can tell you with an Edelbrock RPM Air Gap intake, 750 holley carb, Edelbrock heads, 10.2:1 CR, full 2.5" exhaust, and a crane roller cam (112 lsa, 107 installed, 230/238 @ .050 duration, .528/538 lift 1.5:1 roller rockers) my 365 cid engine (.030 over 360) makes 340 rwhp @ around 5800 rpm (iirc, don't have dyno chart scanned yet or with me) and around 345 rwft-lbs (don't remember torque peak but think it was around 4500 rpm). I pull 13-15 in. Hg vacuum at idle, power brakes still work fine. Hope that helps!
[Re: madmax2]
#106839
08/23/08 01:14 PM
08/23/08 01:14 PM
Posts: 755 Tempe, AZ
loco340cuda
Tempe, AZ
Here is another data point for you. 340/417 stroker motor with an Edelbrock RPM Air Gap intake, 770 Holley Street Avenger carb, Stock 'X' heads, 9.5:1 CR, full 3" exhaust, and a Mopar Performance 484 cam (108 lsa, 241/241 @ .050 duration, .484/484 lift 1.5:1 stock rockers) this engine was chassis dyno'd and makes 375 rwhp @ 5400 rpm (the clutch started to slip so they shut it down, if the clutch would have held I believe there is a little more HP in the motor then what was measured) and 484 rwtq at 2700rpm). It pulls 11 in. Hg vacuum at idle. I have power brakes and it works fine. The motor has a nice mean sounding idle with a little bit of chop to it.
70 Cuda 340 4 speed - now stroked to 416ci (SOLD) 2017 Mustang Shelby GT350
