Recomendations for adjustable timing chains #1065550
08/30/11 01:41 AM
08/30/11 01:41 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Hi all
I was wondering which adjustable timing chain and cover do you all recommend? I was looking at the comp cam one, and while is is nice, it is pretty pricey!
What do you all use?
Mike
1969 Dodge Dart Swinger
Re: Recomendations for adjustable timing chains [Re: MikeyT] #1065551
08/30/11 11:30 AM
08/30/11 11:30 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I always bought the Cloyes brand and have had no issues. The last time, I took a chance and ordered a Summit house brand figuring I would return it if I did not like the quality of it.
It was a Cloyes in a different box,had all the same numbers stamped in everything.
Last I knew Cloyes made the ones for Comp Cams also.
Keith
Re: Recomendations for adjustable timing chains [Re: MikeyT] #1065552
08/30/11 02:31 PM
08/30/11 02:31 PM
Hi all
Mike
You must be talking about a SB cover and chain, why not buy a good timing set and forget about the chain strechting(SP?)
