Re: MSD should build these for the Flat Heads !
[Re: THE GLASS MAN]
#1065438
09/02/11 02:00 AM
09/02/11 02:00 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
Wouldn't it be nice if you could get on the phone and order a MSD distributor for your Dodge or Chrysler Flathead 6. I honestly think MSD would make them if there were enough interest. Does anybody make a new distributor for these motors?
im sure MSD would make them ,,or adapt one to fit, does pertronix make a kit for the dizzy your working with ???
arrington engines does modern HEMI stuff, they had MSD make a dizzy to fit there redesigned timing cover for the 5.7 6.1 hemi to convert it to a dizzy so no computer is needed,,problem is,,, the conversion package is WAAAAY over priced,,they may of sold 3 kits,,maybe,,
but MSD would probably do some thing if you got a hold of the right person
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: fstfish66]
#1065439
09/02/11 03:29 PM
09/02/11 03:29 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You do realize you can use your points to run an MSD box. The current thru the points would be minimal and they'd like last forever. Assuming teh distributor is in good shape to begin with no need to replace it.
