what jet size to use in a nitrous flow tool? #1064016
08/27/11 05:24 PM
08/27/11 05:24 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
what size jet should i use on my nitrous fuel flow tool?what pressure flowing should i baseline it at?i was told 5-5.5 psi,its a
cheaters plate with .055n/.045f.thanks mike
Re: what jet size to use in a nitrous flow tool? [Re: hp340nos] #1064017
08/27/11 08:04 PM
08/27/11 08:04 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
Dont you use the jet that you are going to use on the fuel size, to set flowing psi? Been awhile since I have done this, so hopefully a nitrous person will chime in.
I remember my friend cutting a jet down to make the tool...but that doesnt help.
And I think psi will depend on your tune up and who you are talking to.
justin
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: what jet size to use in a nitrous flow tool? [Re: wldtm] #1064018
08/27/11 09:05 PM
08/27/11 09:05 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
You always flow check with the same size jet, it's just a reference point and needs to be kept constant to know how much of a change you made. 73 jet is the preferred size I recall.
Re: what jet size to use in a nitrous flow tool? [Re: Bigcube] #1064019
08/27/11 10:12 PM
08/27/11 10:12 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
.073 is what I always used.
Leon
Re: what jet size to use in a nitrous flow tool? [Re: Leon441] #1064020
08/27/11 11:30 PM
08/27/11 11:30 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
i will use a .073 jet then,thanks mike
Re: what jet size to use in a nitrous flow tool? [Re: hp340nos] #1064021
08/28/11 12:10 AM
08/28/11 12:10 AM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
http://www.yellowbullet.com/forum/showthread.php?t=351146&highlight=flow+test
some good info. sorry for posting info that may have been misleading or wrong. i know why we did it this way, but it sounds like it doesnt really matter.
justin
Re: what jet size to use in a nitrous flow tool? [Re: wldtm] #1064022
08/28/11 12:49 AM
08/28/11 12:49 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
The flow tool I got from Monte Smith has a .073 in it.
Re: what jet size to use in a nitrous flow tool? [Re: wldtm] #1064023
08/28/11 03:38 PM
08/28/11 03:38 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
justin
That's a pretty funny thread ......a 20 jet swing EACH WAY is only about a 1/4LB of fuel pressure difference.......That's like peeing in the ocean to raise the tide in nitrous tuneups....
If you can't handle the truth, you're living a lie.......
