Re: 1967 Plymouth Satellite question??
[Re: Dart1031]
#1063741
08/27/11 10:09 AM
08/27/11 10:09 AM
Posts: 5,160 Texas
dannysbee
Texas
With the right wheel a 28"x 9" slick or a 275-60-15 radial.
Getting old just means you were smarter than some and luckier than others.
[Re: dannysbee]
#1063742
08/27/11 10:25 AM
08/27/11 10:25 AM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
Here is a 255/50-16, 8 inch wheel. It does rub slightly on the inside on driveways and hard cornering.
8.30's @3400 lbs
[Re: Cudafied]
#1063744
08/27/11 02:02 PM
08/27/11 02:02 PM
Posts: 319 Denver
Explodo
Denver
The upper part of the outer wheelhouse slants in at the top. There doesn't appear to be any body-clearance issue that caused this to be done, so I'd guess it was just a case of reusing parts by Chrysler. Keep that in mind when doing fitting. Just because it fits at the bottom without rubbing doesn't mean it will fit up top.
'67 440 Satellite
[Re: Explodo]
#1063745
08/27/11 02:19 PM
08/27/11 02:19 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I concur, a 255/60-15 is the largest that will not be a pain in your a$$. Nice looking car, Is it origionally a Belvedere? or did someone change the trim (does not have Satellite sill trim). I think the Belvedere / GTX lower sill trim looks nicer, personally. If I ever paint my car, I may go that direction. If it was origionally ordered that way, that's a pretty rare piece! Also, the headrest seats is UBER-rare.
[Re: StealthWedge67]
#1063746
08/27/11 10:26 PM
08/27/11 10:26 PM
Posts: 846 Long Island, NY
Cudafied
Long Island, NY
I just picked the car up on Wednesday, so I'm still taking it all in. This is my first pre 68 B-body.
The car is a Satellite Vin RP23. One of the previous owners had the car documented by Galen Govier, he broke down all the codes from the build sheet, fender tag, certicard and some other stamped locations around the car. As far as I can tell from reading through it everything is original as ordered. So I guess that's good P.S. It also has AC, power steering and power drum brakes
[Re: Cudafied]
#1063747
08/28/11 02:47 PM
08/28/11 02:47 PM
StealthWedge67
Puyallup, WA
What engine package? That's a nice one for sure. Great color combo (red int. isn't something you see everyday), Lots of options, rare exterior trim package, Headrest seats, Especially if its a 383 car I'd say keep that one original. As you get to know 67 Satellite's a little better, you'll see how special that car is. I've personally never seen a set of the headrest seats, and I've never seen one with the Belvedere ext. trim. (I'd bet it had to be factory ordered special that way - ???) It also still has the bumper guard's (those usually get tossed when the bumpers get re-chromed). May I ask how much you paid for it?? Nice car for sure!
#1063748
08/28/11 05:51 PM
08/28/11 05:51 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I've never seen an original 67 Satellite without the Satellite lower body trim, it's more likely someone removed it and replaced the wheel opening moldings and lower body moldings with Belvedere/GTX items. If you have the Broadcast Sheet I'd like to see a copy of it, if the molding is in fact factory delete that would be one special car!
[Re: ScottSmith_Harms]
#1063749
08/29/11 11:18 AM
08/29/11 11:18 AM
Posts: 1,413 Newark,Ohio
kissmyaspen
Newark,Ohio
my dads has 29.5x9x15's on his that a michey slick.
79 Dodge Aspen 12.265 at 109.75 MPH
67 Satellite NSS/E 11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street. '07, '10, '12 Mopar Nats runner-up Street.
