what e.t. gain from a cheater plate at .055 jets? #1063059
08/25/11 09:17 PM
08/25/11 09:17 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
what type of et gain can i expect from a cheater plate set-up with .055n/.045n jets?
88 dakota 3400# street/strip
pump gas 9.7:1 comp, 340 stroked to 418
herbert roller cam .580.600 lift
full ported/polished x heads
aed 850 carb
727 manual v-body
10" converter 4100rpm flash stall on motor
8 3/4 3.91 posi
new m/t drag radials in a 295-55-15
3 way drag shocks on middle setting
rear has cal-trac style set-up
truck ran a best last sat in the heat of [Email]7.37@94.1[/Email] with a 1.63 60ft.on motor.i drive it to the track 35-40 minutes one-way.any ideas on gains?my nos tune-up is as follows;
.055n/.045 f
plug gap at .030 autolite 65 plugs
timing set to 30* for nos on motor its 36-37*
i still have to set flowing fuel pressure i was told 5-5.5psi.fuel system for nos is dedicated blue pump, reg ,-6 braided line.thanks mike
Re: what e.t. gain from a cheater plate at .055 jets? [Re: hp340nos] #1063060
08/25/11 09:39 PM
08/25/11 09:39 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
with that tune up maybe 3 tenths with hitting it out of the hole.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: what e.t. gain from a cheater plate at .055 jets? [Re: 1967dartgt] #1063061
08/25/11 10:02 PM
08/25/11 10:02 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
forgot to add i have a bottle heater and purge also hooked up.ive ran nitrous many times before but at larger jet sizes.mike
Re: what e.t. gain from a cheater plate at .055 jets? [Re: hp340nos] #1063062
08/25/11 10:49 PM
08/25/11 10:49 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Well into the 6's Mike!
Re: what e.t. gain from a cheater plate at .055 jets? [Re: Bigcube] #1063063
08/26/11 11:55 AM
08/26/11 11:55 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
prolly half a second in et..mabey 7/10ths at the most.
I run a .65 jet/pill and get right at a full second reduction in et..fwiw
.055 pill ...it is enough shot to feel it in your seat though thats for sure
i might go a hear range or 2 cooler on that spark plug....if tune is good..it might be fine.
but any more of a shot/pill id go colder on teh plug.
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: what e.t. gain from a cheater plate at .055 jets? [Re: cheapstreetdustr] #1063064
08/27/11 12:34 AM
08/27/11 12:34 AM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
i would be real happy with a 6.98 or better.thanks for the replys.mike
Re: what e.t. gain from a cheater plate at .055 jets? [Re: hp340nos] #1063065
08/27/11 02:08 AM
08/27/11 02:08 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I dropped from 8.2s to 7.5s with issues on 47n-55f jets, MPH i gained 11, So i'll say easy 6.8s, should go 6.7s from 8.3s, i'll give it 6 tenths, I think a 63n jet would give you a solid 8 tenths.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: what e.t. gain from a cheater plate at .055 jets? [Re: joedust451] #1063066
08/27/11 04:22 PM
08/27/11 04:22 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I did this for a freind with a 100% street nova show quality car stock suspension. He was racing with drag radials.
Put a similar tuneup on it and picked up .9. He would not let me play with it to try and get a full second. He almost peed himself he was so tickled in how the car ran.
Leon
Re: what e.t. gain from a cheater plate at .055 jets? [Re: Leon441] #1063067
08/27/11 05:15 PM
08/27/11 05:15 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
thats a nice gain leon.mike
