Would this be an ok blower cam? #1062902
08/25/11 04:48 PM
08/25/11 04:48 PM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Putting together a 470 and I'm throwing around the idea of a Procharger setup. Probably aim for 8 psi boost if I go this route. This will be a street cruiser and occasional highway driver. Would this cam be ok for a mild blower setup? http://www.compcams.com/Company/CC/cam-s...CookieSupport=1
Also would the Procharger be any harder on a bronze distributor bushing than a naturally aspirated engine? Thanks
Re: Would this be an ok blower cam? [Re: 70VcodeCoronetRT] #1062903
08/25/11 05:47 PM
08/25/11 05:47 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
with a little lower cr like 8/1.have you ran the cam on the wallace calc to see what the cranking cr might be?will you run pump gas?if so you could run a dial back timing on the dash for when you get on it.i am sure someone will have something to say about quench.i am not sure you need more than stk stroke but a 470 would be fun.you have a lot of detail to figure out but thay all take planning.
some info i ran.
Static compression ratio of 9.5:1.
Effective stroke is 3.54 inches.
Your dynamic compression ratio is 8.01:1 .
Your dynamic cranking pressure is 159.23 PSI.
Your dynamic boost compression ratio, reflecting static c.r., cam timing, altitude, and boost of 8 PSI is 12.37 :1.
V/P (Volume to Pressure Index) is 203
Re: Would this be an ok blower cam? [Re: 70VcodeCoronetRT] #1062904
08/25/11 10:13 PM
08/25/11 10:13 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
not the cam for you, stick with 114 lsa 112 icland and no more than 240 duration @ .050
MOPAR OR NO CAR
Re: Would this be an ok blower cam? [Re: hemigod426] #1062905
08/26/11 07:29 AM
08/26/11 07:29 AM
Nebraska
Nebraska
Ok thanks guys. When I bought the cam I was and maybe still will be using it in a NA 470.
