727 problem
#1062713
08/25/11 07:03 AM
08/25/11 07:03 AM
Posts: 525 Can , Nova Scotia , Cape Breto...
caper
When I was at test and tune last night, when you pust the tranny brake ( griner ) button the car would lurch backward. Anybody know what is causing this? Could it be caused by a front band adjustment too loose?
sheldon
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: 727 problem
[Re: caper]
#1062714
08/25/11 09:05 AM
08/25/11 09:05 AM
Posts: 20,600 in a cattle trailer down by th...
Guitar Jones
sheldon
No, the front band isn't even in use at that point. My guess would be a loss of pressure to the rear clutch assembly or worn rear clutches. This could be clutch seals, valve body leakage, worn bushings or seal ring surfaces. How long has it been together or is this a fresh build?
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: 727 problem
[Re: caper]
#1062715
08/25/11 09:12 AM
08/25/11 09:12 AM
Posts: 52,972 Romeo MI
MR_P_BODY
sheldon
Check the adjustments... reverse and low are applied and in your case reverse is winning
Re: 727 problem
[Re: MR_P_BODY]
#1062716
08/25/11 10:37 AM
08/25/11 10:37 AM
caper
I also notice that when you put it in low it doen't engage untill you rev the engine a bit. It was rebuilt last summer , about 60 runs on it. What adjustments do you mean?
Re: 727 problem
[Re: caper]
#1062717
08/25/11 11:28 AM
08/25/11 11:28 AM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
The low band adjustment is inside the pan if it's loose, but the delayed engagement is a tell tale that it may be something hydraulic vs an adjustment.
Re: 727 problem
[Re: POS Dakota]
#1062718
08/25/11 11:39 AM
08/25/11 11:39 AM
Guitar Jones
No adjustment is going to fix that, you are losing pressure somewhere.
Re: 727 problem
[Re: Guitar Jones]
#1062719
08/25/11 11:59 AM
08/25/11 11:59 AM
POS Dakota
detroit, mi
yeah, that's pretty much my thought on it. and the longer the delay in resolving it, the more damage.
